Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Carbs
Old 02-13-2008, 02:14 PM
UpOnOne781's Avatar
Default Carbs
Hey everyone im lookin at different carbs and im not sure which one to get...I got a SBC 350 and im gunna have 64 CC aluminum heads...any suggestions on a brand or anything???
Old 02-13-2008, 02:33 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
without knowing cam specs, compression, intake, etc., what car is being used in, what trans and gearing or what you will be using it for I'd be ballparking this.
I've run a 750 vac. secondary Holley on my 72 Chevelle (vs. a double pumper for the weight of the car and the times I was turning at that point, mid 13s), and my Nova had a 650 Holley double pumper that got it from high 12s all the way to mid 11s without a bunch of mods. Currently using a 750 Holley HP double pumper, and it was a tenth faster out-of-the-box over my 650, but without a choke it might be considered not as street friendly to some.
End result - more information is needed to make a clear choice.
Derek
Old 02-13-2008, 05:34 PM
UpOnOne781's Avatar
alright thanks...ill get back to u wen i decide what compression im gunna use...prolly 10:1 with a radical cam...still lookin at a few things...ill post another thread when i got everything planned out all the way...
Old 02-13-2008, 06:58 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, a 650 vac secondary, if you are looking for more a 750. I use a 750 vac sec and a 750 pro form mech sec for racing.
Old 02-13-2008, 07:55 PM
Shawn @ VA Speed's Avatar
holley 670 street avenger
Old 02-13-2008, 08:32 PM
LS WHAT's Avatar
go with a quick fuel
Old 02-13-2008, 09:11 PM
In-Zane Moderator
ZONES89RS's Avatar
Quick fuel and pro form are the same.
Old 02-13-2008, 10:43 PM
Rogue86's Avatar
Call pro-systems carbs. You'll never regret it.
Old 02-14-2008, 03:31 AM
In-Zane Moderator
ZONES89RS's Avatar
Pro systems reworks carbs too right?
Old 02-14-2008, 04:26 AM
mtperformance's Avatar
I recently fell in love with the Demons.
Old 02-15-2008, 04:29 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1140
I have a Holley 700 double pump in stock for a great price, shown above. The 700 is a great all around carb for many applications. Bob
Old 02-15-2008, 10:11 AM
6 & 8 Second Club
mrdragster1970's Avatar
Really need specs & application, as said. IIRC I used a 700 dp & a 780 vac on my last 350. Just depends on how wild or mild.
Old 02-15-2008, 11:36 AM
UpOnOne781's Avatar
wuts the best way to determine how much cfm i should need??
Old 02-15-2008, 02:22 PM
BIG NASTY's Avatar
With a 350ci a Holley 750 4150 series is what I ran for 2 years on my DD and it has great performance I ran mid 12s all day on motor and 11.26 with a 150shot not bad for a vortec motor. There is a formula that help to come up with the cfm but its just a guide.
Old 02-25-2008, 07:23 PM
EPP
EPP's Avatar
Here is good info from Holley.
http://www.holley.com/data/TechServi...Carburetor.pdf bOB
Old 02-26-2008, 03:44 AM
JUICED96Z's Avatar
Same here, have a BG 850 that flows 1.040 CFM! When I buld the car up more and have the need for a larger carb I am sure I will go Deamon.
Quick Reply: Carbs
