Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > Small Block & Big Block Chevy Specific
Old 04-12-2008, 07:47 AM   #1
My Garage
Formula_LT1's Avatar
Trader Rating: 2
Default Whats a cast iron/steel SBC crank rated at HP wise?
Just like the title says......What HP level would someone want to start looking into buying a forged crank?
__________________
1997 Trans Am
355, Ported heads/intake, Joe Overton Cam, Full Bolt-ons, M6, 3.73 rear end, Nitto DR.
1981 Chevy Malibu- On the back burner.
Working on a LS1-Th350 swap.
Formula_LT1 is offline   Reply With Quote
Old 04-12-2008, 01:12 PM   #2
My Garage
moge11's Avatar
Trader Rating: 0
Cast iron is NOT steel....its cast Iron...the Steel cranks are your Forged ones.
The stock cast cranks are good to 450-500hp.
__________________
1985 Camaro IROC-Z_original SILVER
Needs an LS1!
T-5 and a spare T-5.
moge11 is offline   Reply With Quote
Old 04-12-2008, 01:39 PM   #3
My Garage
MrOverkill's Avatar
Trader Rating: 0
I have run factory steel 350 crankshafts past 700hp and 7500rpm w/o issue in the past, assuming the machine work, clearances, assembley are all correct they can live a long life. It does matter what the application, I wouldnt run one in a manual trans drag car or heavy car w/ a trans brake. But for a street killer or roundy round engine you cant go wrong if your on a budget..........
__________________
Small Tire 72 Chevelle Street Car NASTY N20 SBC/Mikes Glide combo looking for mid 9's on a conservative tune up
MrOverkill is offline   Reply With Quote
Old 04-12-2008, 07:06 PM   #4
LS1TECH Sponsor
My Garage
Trader Rating: 1
There are cast steel crankshafts,the eagle cranks are cast steel,then you have forged steel.I have run as much as 650hp on a cast crank in a sbc,but alot of it depends on the crank design,i have run 1000hp on an ls1 cast crank
__________________
www.virginiaspeed.comcustom engines for street or race,custom cams,installs,any other parts you need,custom cams for $395.00,402 iron shortblocks from $4150.00,custom tuning in house,dealers for Precision turbo,Comp Cams,Lunati,JE,Nlr-ams1000,Callies,ATI,TEA,Mahle,Brodix 757-468-5101
1979 Z28 Outlaw 10.5-670bbc twin promod 94's
Crew Chief and tuner of Phil Thomas's
LSX powered Mustang"The Renegade" 7.59@191 on 315 radials at 3315lbs
Shawn @ VA Speed is offline   Reply With Quote
Old 04-12-2008, 07:13 PM   #5
My Garage
TLewis4095's Avatar
Trader Rating: 9
Ive got a great SBC cam & lifter set brand-new in the box cheap if interested:
Comp Cams CL12-224-4 Details
Chevy 262-400ci Small Block 1955-98
*Note: In order to use these camshafts in 1955-57 265ci blocks, it is necessary to machine a small groove in the rear main journal of the cam to allow oil flow to the top of the engine.
Maximum street performance, very rough idle, needs headers, 3000 stall and 9.5:1 minimum compression. Operating Range:2500-6500 RPMDuration Advertised:294° Intake / 294° ExhaustDuration @ .050'' Lift:248° Intake / 248° ExhaustValve Lift w/1.5 Rockers:.525'' Intake / .525'' ExhaustValve Setting:.022'' Intake / .022'' ExhaustLobe Separation Angle:110°
Sells for $218 in Jegs,
$175 1 only. This is the complete kit w/lifters. $15 S&H.
This cam makes power!!
TLewis4095 is offline   Reply With Quote
Old 04-12-2008, 07:59 PM   #6
In-Zane Moderator
My Garage
ZONES89RS's Avatar
Trader Rating: 4
I hope my scat 9000 crank holds up to 7000 rpm and N2O.
__________________
BUILT NOT BOUGHT
www.fquick.com/zones89rs
Quote:
Originally Posted by JUICED96Z View Post
The weight argument it stupid, compare a Warhawk LS motor to a all aluminum BBC, the weight difference is worth it to me with the kazillion more cubes.
ZONES89RS is offline   Reply With Quote
Old 04-13-2008, 05:19 AM   #7
My Garage
1970camaroRS's Avatar
Trader Rating: 0
Send a message via AIM to 1970camaroRS Send a message via MSN to 1970camaroRS Send a message via Yahoo to 1970camaroRS
Quote:
It will as long as you limit the ammount of time it's exposed to that RPM level. There are four things to consider when looking at cranks. Power level, RPM, and time spent at high rpm, and any potential shock loads such as a manual trans car, or nitrous. Cast cranks will stand up to high power levels and high rpms. Do it for any length of time and the crank will want to bend and eventually break. Shock loads on a cast crank can actually bend it, leading to failure.
__________________
1970 Camaro, LQ4, WC stg2 LS6 heads, G5X3 cam, 700r4, lots of fiberglass
2000 Camaro SS, M6, Black on black on black, with some more black.
1970camaroRS is offline   Reply With Quote
Old 04-13-2008, 09:26 AM   #8
My Garage
TLewis4095's Avatar
Trader Rating: 9
Quote:
Agreed, and any resonance or harmonics that may come into play at those RPMs can be catistrophic. EVERYthing must be balnced correctly.
Tech Talk Article 2
"Reher's Rule:
RPM Determines Reliability"
by David Reher
Page 1
This is the time of the year when a racer's thoughts turn to next year. The brief break between seasons provides a welcome opportunity to spend some time thinking rather than wrenching. In that spirit, I'd like to suggest that the decisions you make in December will have an enormous impact on your chances of winning races next summer.
The most important thing a racer can do right now is to develop a plan. Without question, the most common mistake in racing is to buy parts impulsively without having a clear vision of where you want to end up. The result is often a pile of mismatched pieces that will never work together properly.
I recognize that not every racer has the resources to buy a complete engine from a professional builder. Even though you may not be able to afford a professionally built motor, it 's still important to think like a pro: You have to select components that will work together as part of a total combination. Think about what you expect the end result to be: the engine's projected horsepower output, its rpm range, and the chassis/powertrain combination. For example, do you plan to use a tight or a loose torque converter? The answer to that question will affect your choice of carburetor, cylinder
port volume, and cam profile.
There is certainly no lack of information on engines, but not all of the available information is valid. Don't be misled by inaccurate magazine articles and armchair engine builders touting this week's hot tip. You really don't need - and you really don't want - a tall-deck block with 7-inch long connecting rods and Pro Stock cylinder heads for a 13-second bracket car. You need pieces that are compatible - pistons that fit the cylinder heads, valve springs that compliment the camshaft, and an induction system that is tuned for the engine's operating range.
Perhaps you're just thinking about upgrading your present engine for next year. Keep in mind that there is almost no part you can change in an engine that does not affect some other component. If you install a bigger cam, you've got to have valvesprings and pushrods that will work with the new profile. If you bolt on parts that allow the engine to turn higher rpm, then you may need to look at improving its lubrication system. Your old oil pan may work perfectly at 7,000 rpm, but if you spin the motor to 8,000, the pan may not be able to control the increased windage. The likely results: aerated oil and spun bearings. Almost invariably, when racers suddenly encounterreliability problems in a previously trouble free engine, it's due to some change that produced an unintended consequence.
The one lesson I've learned in 30 years of building race engines is that rpm plays a major role in determining reliability. It is simply impossible to turn and engine faster and have it last longer. Higher engine speeds not only increase the loads on engine components, but also increase the number of cycles that each piece must endure. Although the actual time spent on the track may be reduced slightly if the car runs quicker, higher engine speed will subject the rod bolts, valves, pushrods, lifters, and every other part to more stress cycles on every quarter-mile run.
Coal miners took canaries into the mineshafts to warn them of poisonous gases. In a racing engine, the valvetrain plays a similar role as an early warning system. Dead valvesprings, like dead canaries, are a sure sign of trouble ahead.
It's absolutely critical to maintain the valvetrain, especially if you are using an aggressive cam profile. The valvesprings are usually the first place that you see the detrimental effects of high rpm. Roller lifters also
require regular inspection and maintenance. We seldom see bottom end problems in an engine, but lifter failures are a constant concern, especially if a racer lets the valvesprings get weak.
My advice to anyone who wants a powerful bracket engine - let's say a big-block that produces in the range of two horsepower per cubic inch - is to use titanium valves. Yes, titanium valves are more expensive initially than steel valves, but they dramatically increase valvespring life and significantly reduce the chances of valvetrain failure. In my opinion, lightweight titanium valves are a good investment for any big-block that routinely runs above 7,000 rpm. I know that the cost of titanium valves is usually far less than the cost of repairing the damage caused by a broken lifter.
We performed a back-to-back comparison test between stainless steel and titanium valves in a 555ci bracket racing Rat motor with ported Dart 360 cylinder heads and a roller cam with .475-inch lobe lift. With steel valves, the engine made 920 horsepower at 7,000 rpm, but the power curve dropped at 7,200 rpm. We pulled the heads, swapped the valves, and had the engine running on the dyno again 90 minutes later. With titanium valves,
the engine had the same power at 7,000 rpm. At 7,200 rpm it was up 20 horsepower, and it maintained that output to 7,800 rpm. Best of all, after two years of racing and hundreds of runs, this engine hasn't broken a valvespring!
When you're making plans for next season, be realistic about your own goals. Do you enjoy working on your engine or do you want to build a low-maintenance motor? A fast race car isn't like a motor home; it requires constant attention. On the other hand, if you want an engine that's as reliable as a refrigerator, you'll have to change your expectations accordingly.
Consider the difference between two of my customers: one runs an auto supply and loves to work on his car; the other owns a successful landscaping and pool business and he doesn't want to take off a valve cover between races. I can't build them the same engine because their requirements are completely different.
A lot of bracket racers really like to go fast, and compete regularly in Quick 16 and Quick 8 shows. Other guys want to make 300 runs without doing anything to their engines except changing the oil and filter. You need to decide which category you fit in before you begin ordering parts. If you don't have the time or interest to work on an engine, use parts
that have a long life and keep the engine rpm low - and don't be disappointed when the guy who is willing to work on his engine has a faster car.
If you'd rather race than wrench, why not build a bigger motor and keep it conservative? There's no replacement for displacement; put a small cam in a big-inch engine and you may be able to get close to your performance goal without spending every evening out in the garage.
So here is the first of Reher's Rules on Race Engines: Maintenance goes up with power. Period.
Old 04-13-2008, 10:12 AM   #9
My Garage
LT1_Fireman's Avatar
Trader Rating: 5
Well I am on a stock crank without issue.numbers in sig.I also have a friend who is making close to the same power as me in his firebird (sb1 conversion) and he launches off of a trans brake every weekend and his crank is holding.
__________________
Ben
2002 Z06 bolt-ons and an 150 shot
1994 B4C Camaro -forged 355(9.4 comp ratio),232/236 568/581 114 cam, accel gen 7,ported trickflows,true 3'' duals,and a D1R ...much more.
LT1_Fireman is online now   Reply With Quote
Old 04-13-2008, 04:12 PM   #10
DRAG RACING IS LIFE! Mod
My Garage
Villain281H's Avatar
Trader Rating: 2
Send a message via AIM to Villain281H
I had a stock GM crank in a 355 SBC that lasted 7 years before splitting into halves Plenty of racing (over 1000 passes), about 50,000 street miles. I wasn't upset. Aftermarket cast cranks are usually rated to 500-550 fwhp with forged uping that # by a good bit (800-1000 fwhp). All depends on what the engine will see for abuse and times it gets abused.
Derek
__________________
1970 Nova SS Clone: 383 SBC on 93 swill, 3600+ lbs., 11.12 @ 119.77 mph N/A, quicker on the jug...
2000 Formula: MACS, ORY, Magnaflow, !EGR, !AIR, Formato tune, stock long block, trans and rear end, still slow
2004 GMC Sierra 1500 ECSB 5.3: Magnaflow CB, K&N CAI, Formato tune, what I haul s**t with
Check out pictures, info and vids: www.fquick.com/Villain281H
"If ignorance is bliss, why aren't more people happy?"
Villain281H is offline   Reply With Quote
Old 04-13-2008, 10:24 PM   #11
My Garage
moge11's Avatar
Trader Rating: 0
I plan to run a scat 9000 in my next build. Thats about the best bang for the buck.
__________________
Needs an LS1!
Old 04-13-2008, 11:19 PM   #12
In-Zane Moderator
My Garage
ZONES89RS's Avatar
Trader Rating: 4
My scat 9000 is shot peened so i guess that helps too, i think it will do for what i have going and i have seen stockers do some crazy shit, especially the roundy pound guys(dirt track/oval).
__________________
BUILT NOT BOUGHT
Tags
cast, crank, forged, gm, high, horsepower, hp, ls, ratings, sbc, spin, steel, stock, weight, whats
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
