Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
having issues with my L98
Old 09-05-2008, 08:58 PM
VETTE60's Avatar
Default having issues with my L98
if anyone has any insight i would appreciate it.
i put an l98 tpi 350 from an 89 vette in my landcruiser. it has been acting up lately. last week on the trail it was stalling out, acting up, and would not start until i let it cool down. it seemed to run very normal when cool. it was idling very rough and would die if i gave it throttle. anyway had it scanned and the o3 sensor was bad. changed that. idles better, but eventually it loads up and then acts as if it is running in 7 cylinders, and the exhaust/cats seem to be way hotter than they should be. BTW i pulled the cats and they are clean and not plugged. also, not throwing any codes...
gonna compression test tomorrow
any ideas? much appreciated
Old 09-05-2008, 09:04 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, that is why i have a carb and not TPI, hopefully a TPI master can chime in.
Old 09-06-2008, 06:01 PM
Kevin91Z's Avatar
Engine problems can happen no matter what intake is on top.
Check the injectors to make sure they're good. One simple method is to ohm test them all when they're cold, and again when they're hot. Pull the clip off one and put the test leads on the tangs of the injector. Anything less than 12 ohms and its definitely bad.
Old 09-06-2008, 09:49 PM
In-Zane Moderator
ZONES89RS's Avatar
Trouble shooting is 10x easier with the carb.
Old 09-06-2008, 11:53 PM
VETTE60's Avatar
thanks, I'll try that!
Old 09-06-2008, 11:56 PM
VETTE60's Avatar
yes....I know this full well...but i do not have a carb! i have a tpi...
and i live in california and can't put a carb on it...
sooo.... anyway i will check the injectors and get back
but i think that it may be something else. usually a very hot cat is either clogged or getting unburned fuel into it so i think it is either an ignition fault or a dead hole...
i appreciate the input.
Old 09-07-2008, 01:35 AM
F-Body Lover's Avatar
hahahahhha carburetor all the way
Old 09-07-2008, 10:26 AM
VETTE60's Avatar
....is this a chit chat section?
so far i have 1 helpful respnse and 3 spam replies....thanks
you can keep those to yourself
moderator anyone?
Old 09-07-2008, 12:14 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, my first post was serious, i did not intend for it to turn into a pissing match.
Old 09-07-2008, 11:11 PM
VETTE60's Avatar
yes, and then a second post about a carb. and someone else chiming in also. once again, i am looking for help with a tpi. you telling me that a carb is easier is not helping.
i am not looking to offend, this is not a pissing match, i am just looking for help with a problem i have, nothing more. and not interested in hearing how a carb is easier. i know that. like i said those comments are better left for the chit chat threads. thanks
Old 09-08-2008, 12:30 AM
VETTE60 dude chill out man ok did you check the timing?fuel pressure?when was the last time you changed the spark plugs? check the injectors like Kevin91Z said and then check the sensors in the throttle bodie I used to have a problem in my 92 Z28 when I give it a throttle it dies the IAC sensor was dirty so check all the sensors and reply to us what happen after that and sorry about the off topic that happend earlier
Old 09-08-2008, 11:16 AM
VETTE60's Avatar
ok, thanks i'll try those suggestions
Old 09-08-2008, 11:25 AM
XtremeModifier's Avatar
First thing I would do (since it's a OHV and thus easier) is pull the spark plugs out and look at them. If they're black, replace. If they look good, look at other things (white is also bad).
Spark plugs are usually the first sign of trouble for me, and the first thing I check on anything other than my diesel (which has none).
Old 09-11-2008, 01:37 AM
Kevin91Z's Avatar
Uhm, how so? It really depends on what you're used to. I can open the hood on a carb'd car, stare at it for a few minutes, and not have a clue how to fix it.
But I can plug my scan tool into an EFI car, read what the computer is seeing, and diagnose the problem fairly quickly. I'm sure you'd be as lost with an EFI car as I would be on a carb car. The extra sensors on an EFI car might seem more complex, but they really do aid in troubleshooting and providing feedback. There is no feedback on a carb car, other than "its not running right."
Old 09-14-2008, 12:24 AM
VETTE60's Avatar
okay...did the cap/rotor/plugs/wires all new. checked the injector resistance. there were a few between 6.8-9 ohms, other injectors were at 16 ohms. i guess i could throw in a new set of injectors. seems like it is running rich though, and my ehuaust feels much hotter than it should be around the cats, which makes me think i am getting a lot of unburned fuel ito the cats which is than lighting off and getting them very hot....btw did a compression check and all holes were at 145 psi. also my oil pressur just started reading very high, but6 i am guessing a new sending unit will probably remedy that. any other ideas. thanks for the help so far.
Old 09-14-2008, 12:43 AM
did you check the IAC?air tempreture sensor?
Old 09-14-2008, 02:16 PM
VETTE60's Avatar
not yet, but i replaced that very recently. i should check it though.
Old 09-14-2008, 09:03 PM
Kevin91Z's Avatar
BINGO! That's your problem. The injectors that are 6.8 to 9 ohms are dead and need to be replaced. They're probably stuck open and dumping fuel, as you say it seems rich.
You should probably replace all 8 to be on the safe side.
Old 09-14-2008, 09:23 PM
FICINJECTORS's Avatar
I agree completely, 6 ohm's and theyre nicely cooked haha!
Multecs are quite unreliable.
I can do a stock replacement set of our rebuilt Bosch Design III's, 22lb for $169.95 + $11.60 shipping to your door. They come flow matched, with Viton o-rings installed, and a 3 year warranty.
For the L98 I also have the complete gasket set, including the rail o-rings for an additional $30, no extra shipping. That way you can get everything you need to get those multec's out for no extra charge.
PM me if your interested, and check out our reviews on Corvetteforum if you like
~Rich
Old 09-15-2008, 11:25 AM
VETTE60's Avatar
~Rich
cool, i'll let you know.
Quick Reply: having issues with my L98
