CHEAP clearance on 346 and Iron Block 402
Old 01-06-2010, 10:12 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Default CHEAP clearance on 346 and Iron Block 402
Guys, we have these here and need them gone, first come first served. Prices do no include shipping.
BOTH ARE NOW SOLD!
346 LS1 with forged pistons, reman crank and rods, crank turned 10/10. New block, new forged pistons - $1644
10cc dome iron block 402, scat crank and rods - $2265
New stock LS1 longblock - $3500
Just give me a call!
Jesse
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 01-09-2010, 10:13 AM
96z28's Avatar
what would you estimate the compresion on the 402 with stock cc 317 heads
Old 01-09-2010, 11:12 AM
5.3LJimmy's Avatar
Depending on piston to deck clearance with a 72cc head and .056" gasket compression is 12.1-12.4:1.
Definitely a killer deal here for someone. Does the 346 have valve reliefs?
Old 01-09-2010, 11:51 AM
The 346 does have valve reliefs.
I believe that with a 72cc head and a 51 gasket that it came up to 11.6 actually, but I will have to check all of my specs again monday morning.
__________________
Old 01-09-2010, 12:02 PM
96z28's Avatar
anyway to get the compresion into the 10's or not
Old 01-09-2010, 05:40 PM
Spectre86's Avatar
Jesse
Interested in partial trade for LS2 shortblock ?
damn I wish this would have been sooner. Had my ls2 shortblock on the stand for a few months gathering more parts to swap in.
Old 01-09-2010, 08:19 PM
No, you will not get the compression down into the 10s
I have had a few calls about it from different people so I will point out here that this IS NOT the shortblock for you if you want a blower. It is a high compression setup.
__________________
Old 01-09-2010, 08:24 PM
96z28's Avatar
not looking to run a blower, justing looking to replace a damaged 5.3 in an 04 suburban but want bigger, i would be a little worried to run 11.5 compression as a daily driver and expect to use regular gas
Old 01-10-2010, 07:47 AM
john563's Avatar
Jesse
I have TSP stage 2.5 5.3 heads on my 346...What would compression be with those heads on your 402
Old 01-10-2010, 12:21 PM
I don't have a calculator with my (on my phone) but I would think it would be dang near 13:1, maybe a little over.
__________________
Old 01-10-2010, 01:12 PM
96z28's Avatar
can you get the AFR 205's w/ 76cc chamber heads
Old 01-10-2010, 03:32 PM
No, you can't. That would be a job for the AFR 225. With the higher compression and cubic inches, the 225 would be an awesome head to run.
__________________
Old 01-11-2010, 06:10 PM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
What would the comp ratio for the LS1 be with LS2 243 heads? 65cc
Old 01-13-2010, 03:00 PM
GhoSStrider's Avatar
I would like to know more about the 346. What kind of pistons and specs on em? So the crank and rods are stock from what I understood. How much power will this shortbock handle?
Old 01-14-2010, 10:47 AM
fastenough's Avatar
x2
I'd be looking to put some ported LS6 heads on this and some nitrous down the road? 150 shot?
Old 01-14-2010, 11:14 AM
It's not going to be any more weak than a stock shortblock for sure, so I don't see why a 150 shot would be a problem.
__________________
Old 01-14-2010, 09:50 PM
Gt 2 Slow's Avatar
What would the 347 be able to hold? I have a magnacharger looking at 10 to 12lbs of boost do you think the stock rods would hold that?
Old 01-18-2010, 08:11 AM
The 402 sold.
__________________
Old 01-18-2010, 08:52 AM
So did the 346, thanks guys!
__________________
Quick Reply: CHEAP clearance on 346 and Iron Block 402
