Huron Speed Turbo Kits - In Stock, NO WAIT!
Old 03-20-2012, 02:09 PM
LS1Tech Sponsor
Superman09's Avatar
Default Huron Speed Turbo Kits - In Stock, NO WAIT!
Here is an intro into the new Huron Speed Single Turbo, truck manifold kit for 98-02 LS1 cars.
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
Here it is! Kits are IN STOCK, ZERO wait time on shipping
Pricing on this kit is $2299.99. You can view and order on our website at:
http://shop.huronspeedproducts.com/F...FBodyTurbo.htm
This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture! Kit includes all components to run either the 38mm or 44mm Wastegate, as well as to run a MAF or not!
All piping is made from 321 Stainless, yes 321!
Components:
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-38mm-44mm Wastegate Adapter Flange
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-All gaskets
-F-body front mount intercoolers brackets w/ bolts
-F-body alternator relocation brackets
All piping made from 321 stainless steel, fully polished.
Requires Turbo, Wastegate, BOV, Oil Lines, and Truck Manifolds to complete
Being a truck manifold kit, you will lose your A/C
You will have to remove or lower front sway bar
Kit retains factory radiator in factory position, just need to add pusher fans
Kits include what you see in the picture below!
Note: Kit's come with BLACK silicone couplers, not the blue you see on the installed vehicle.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-21-2012, 10:07 AM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 03-22-2012, 11:33 AM
twin74s's Avatar
Shouldnt the crossover have a flex section? Seems like it would cause some cracking issues with no place to give.
Old 03-22-2012, 01:02 PM
LS1Tech Sponsor
Superman09's Avatar
We've never had or seen that issue! Also I do not see many other set ups use flex piping, I always try to avoid as I've had some bad experiences! This section shouldnt flex enough to cause any issues, hope this helps!!
Old 03-22-2012, 06:22 PM
LS1Tech Sponsor
Superman09's Avatar
ToTheTop!
__________________
Old 03-25-2012, 08:41 PM
LS1Tech Sponsor
Superman09's Avatar
PT88 fits! Will have to fab a new down pipe to fit the larger 4" v-band outlet, but everything else looks good to go!!!!
__________________
Old 03-29-2012, 06:46 AM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 04-03-2012, 05:07 PM
LS1Tech Sponsor
Superman09's Avatar
All kits have SHIPPED! More in stock ready to go!
__________________
Old 04-09-2012, 07:31 PM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 04-09-2012, 09:06 PM
tsquared38016's Avatar
Default Turbo Kit
Anything for a first gen running a 2004 LS6?
Old 04-09-2012, 09:11 PM
LS1Tech Sponsor
Superman09's Avatar
Currently we only have 4th gen LS1 kits. I am not sure what all could be compatible to fit a 1st gen.... sorry!
__________________
Old 04-18-2012, 06:32 AM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 04-22-2012, 01:36 PM
PRAY HRD's Avatar
can you post a pic of your alt relo bracket installed and a price please? trying to find something simple and a bit more reasonably priced than what i've seen out there and looks like yours could be it. Only question i think i have is how do you adjust the alternator to get tension on it and to even get the belt on to begin with.
thanks!
Old 04-22-2012, 06:40 PM
LS1Tech Sponsor
Superman09's Avatar
thanks!
The kit relocates both the alternator as well as the tensions, so you still retain the tensioner!
Currently we are only including these in our kits and not selling individually, however we may in the near future if the demand is there for them outright!
Jon
__________________
Old 04-22-2012, 07:06 PM
PRAY HRD's Avatar
10-4 thanks!
Old 04-23-2012, 11:14 AM
airforcemanss's Avatar
Is there a c6 manifold kit that would retain A/C?
Old 04-23-2012, 11:18 AM
LS1Tech Sponsor
Superman09's Avatar
Currently we only have the truck manifold kit. We may in the future do a retaining AC kit
__________________
Old 04-27-2012, 08:23 AM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 05-07-2012, 06:44 AM
LS1Tech Sponsor
Superman09's Avatar
Anyone interested in a kit, PM me to receive a coupon code to save big on a kit!
__________________
Quick Reply: Huron Speed Turbo Kits - In Stock, NO WAIT!
