Huron Speed Turbo Kits - In Stock, NO WAIT!
Here is an intro into the new Huron Speed Single Turbo, truck manifold kit for 98-02 LS1 cars.
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
Here it is! Kits are IN STOCK, ZERO wait time on shipping
Pricing on this kit is $2299.99. You can view and order on our website at:
http://shop.huronspeedproducts.com/F...FBodyTurbo.htm
This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture! Kit includes all components to run either the 38mm or 44mm Wastegate, as well as to run a MAF or not!
All piping is made from 321 Stainless, yes 321!
Components:
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-38mm-44mm Wastegate Adapter Flange
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-All gaskets
-F-body front mount intercoolers brackets w/ bolts
-F-body alternator relocation brackets
All piping made from 321 stainless steel, fully polished.
Requires Turbo, Wastegate, BOV, Oil Lines, and Truck Manifolds to complete
Being a truck manifold kit, you will lose your A/C
You will have to remove or lower front sway bar
Kit retains factory radiator in factory position, just need to add pusher fans
Kits include what you see in the picture below!
Note: Kit's come with BLACK silicone couplers, not the blue you see on the installed vehicle.
Components:
-MAF Delete pipe
-All gaskets
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
ToTheTop!
__________________
PT88 fits! Will have to fab a new down pipe to fit the larger 4" v-band outlet, but everything else looks good to go!!!!
__________________
__________________
All kits have SHIPPED! More in stock ready to go!
__________________
__________________
Currently we only have 4th gen LS1 kits. I am not sure what all could be compatible to fit a 1st gen.... sorry!
__________________
__________________
can you post a pic of your alt relo bracket installed and a price please? trying to find something simple and a bit more reasonably priced than what i've seen out there and looks like yours could be it. Only question i think i have is how do you adjust the alternator to get tension on it and to even get the belt on to begin with.
thanks!
thanks!
thanks!
thanks!
Currently we are only including these in our kits and not selling individually, however we may in the near future if the demand is there for them outright!
Jon
__________________
Currently we only have the truck manifold kit. We may in the future do a retaining AC kit
__________________
__________________
Anyone interested in a kit, PM me to receive a coupon code to save big on a kit!
__________________
