NastyPerformance Race Fuel Tank
We are proud to finally offer our F-body Race tank. It has been completely redesigned to offer the best fit and performance available. The tank fits in the stock location without any modifications and holds about 15 gallons. There are several baffles inside the tank to help sloshing and the sender to work perfectly. The sender mount is complelely billet and holds the stock sender in the correct location. The performance sump should clear most exhaust systems and provides 2 outlets for even the most extreme of setups. Can add the pump and filter mounts to the tank as well(as pictured).
Fits 93-98 with some GM parts $60.00
NastyPerformance 93-02 F-Body Race Fuel Tank $499.95 Intro Special $435.00
Add $25 for the pump mounts
Have a great day Nate
These are on the shelf and ready to ship.
I am sure we could do something custom for you. I just do not know where to get enough space for 24 gallons? Do they require it to be double walled?
Nate
Nate
It is a new line we picked up SX very high quality. The pump retails for $389.95 I sell it for $359.95.
Kyle how you been I have not heard from you in a while.
Nate
Nate
Jammer it is of way higher quality and will last longer than the Aeromotive stuff and is quieter. It is a much larger pump than the 420L and slighty louder.
The fittings in the sump are -10 Your tank is on the way.
Nate
Nate
