Strange 12 Bolt
Old 12-04-2004, 03:11 AM
BOWTIE's Avatar
Default Strange 12 Bolt
Any sponsors want to offer a low volume GP (getting a large GP together this time of year would be almost impossible) or any kind of special discount on a Strange 12 bolt. I would want one with all of the options and either 3.73's or 4.11's. That is I would want the extra strength posi, set up for ABS and traction control, with a girdle cover and stock diameter studs.
Old 12-05-2004, 11:18 AM
tbyrne's Avatar
We can expect our offer from last week if anyone wants to place an order -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars)
$2189.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin)
$2189.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles.
The backing plates are only required for 1998+ cars.. $229.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
ORDER LINE - 1-877-4-TBYRNE
SEND US E-MAIL
WE HAVE MOVED TO A NEW FACILITY - UPDATED CONTACT INFO AND ADDRESS
Old 12-05-2004, 11:13 PM
BOWTIE's Avatar
I have seen the reluctor rings on sale for $20.00 each on other sites, could you also supply those so those of us that are not down could continue to drive our vehicles while the rear end is being built? Also, what is the lead time on a Strange 12 bolt?
Old 12-06-2004, 07:29 AM
tbyrne's Avatar
Do you have a part # for them? I've asked Strange about this many times but they keep saying that the rings aren't available seperate (at least to them). We can get these if it's a GM part number.
Old 12-06-2004, 12:50 PM
badeSST's Avatar
It would be a lot more convenient if we could have the reluctor rings already built in. I don't want to lose trac control, and I don't want to take my axels out of my stock rear either.
Old 12-07-2004, 06:02 PM
tbyrne's Avatar
No go on those reluctors. The SLP rings are inboard.
Old 12-07-2004, 06:20 PM
Billingsley Racing's Avatar
We have the ABS/TCS reluctor rings in stock for $49 pr. Let us know if we can help.
Old 12-07-2004, 06:24 PM
badeSST's Avatar
So that means i could buy them from you and have them shipped to strange so I could bolt in the rear and still have trac control and abs correct?
Old 12-07-2004, 06:40 PM
tbyrne's Avatar
You will also need the brake backing plates. Those can either bought outright or use one of the cores that we keep in rotation if they are available.
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL -tbyrne@tbyrne.com
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
Old 12-07-2004, 06:46 PM
Correct. In fact, if you supply us with a RGA# from Strange, we can send them there direct.
As Tom said, you will need the backing plates also.
Old 12-07-2004, 07:04 PM
badeSST's Avatar
Thanks guys, I was aware I still needed the backing plates just forgot to add that. I am definately going to be needing a rear soon since i have a blower on the way.
Old 12-08-2004, 09:54 AM
JoeT/A's Avatar
Can you accomodate 4.30 gears?
Quick Reply: Strange 12 Bolt
