FLP----Alston Torque Arms???
Old 12-07-2004, 09:17 PM
Restricted User
CAT3's Avatar
Default FLP----Alston Torque Arms???
Need some info and pricing etc on the Alston Torque Arm like PSJ has. Looking to be the best choice for those with True Duals/X Pipe setups!!!!
Thanks
Charlie
Old 12-07-2004, 10:18 PM
Tally TransAm's Avatar
curious as well
Old 12-08-2004, 04:18 AM
BLASTER's Avatar
Is the Alston chromoly? Does it/can it have a pinion angle finder?
Old 12-08-2004, 08:11 AM
HumpinSS's Avatar
Intrested also
Old 12-08-2004, 03:21 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I don't remember if mine is chromemoly or mild steel, but if chromemoely is available then I have it of course.
Old 12-08-2004, 03:32 PM
maddboost's Avatar
I can sell the Alston Torque Arm for $305 normally $325. Its adjustable and is made out of mild steel. Price exludes shipping. Email me or give me a call at the shop if you would like to place an order phil@flp2win.com or 877-FLP-2WIN.
Old 12-08-2004, 05:01 PM
Race your car!
JL ws-6's Avatar
anyone have a pic of this tq arm.. I maay be changing the spohn one off my car ( ground clearance problems
Old 12-08-2004, 05:20 PM
m6z
m6z's Avatar
Im also interested if it clears tsps duals
Old 12-08-2004, 05:24 PM
maddboost's Avatar
Heres a picture off PSJs car.
Old 12-08-2004, 08:20 PM
Restricted User
CAT3's Avatar
Phil,thanks for the post up in here, I was about to email you back to see if I could post up the prices and contact number. Will be ordering mine at the end of the month, too much Christmas stuff for now. Thanks again.
Old 12-08-2004, 08:28 PM
BLASTER's Avatar
DUmb questions.......
How do you install it? Take the driveshaft out? I realize you will have ho pull the interior for the bolts going through the floor. Where exactly do you bolt it to in the tunnel? Ther are no marking. Thanks
Old 12-08-2004, 08:29 PM
2w0s060's Avatar
So it actually bolts to the floor board, does this require drilling/welding?
Old 12-09-2004, 11:04 AM
LS1Tech Co-Founder
The tunnel brace bolts to the floor, if you look in the pic there is the brace it was just painted.
Old 12-09-2004, 11:47 AM
maddboost's Avatar
No welding but requires alot of drilling and you have to remove alot of interior components, center console, carpet, seats to do it.
Old 12-09-2004, 07:31 PM
9 Second Club NA
Dragaholic's Avatar
I had to run a H-pipe true dual system because my Spohn torque arm wouldnt allow an X setup. I like the clearance for the X setup on the Alston, but how would it compare to the Spohn torque arm as far as power goes? The Spohn bolts to the floor board too, in place of the tunnel brace, but it uses a beefy crossmember. The only reason for me wanting to do this swap would be for the clearance to run a X setup. Do they make this piece in chromoly and you just dont happen to offer it, or do they not make it in chromoly all together? Thanks.
Old 12-10-2004, 05:32 AM
Race your car!
JL ws-6's Avatar
This piece does look good, only reason I am considering it is bacause the spohn unit that I am currently running had to be shimmed down to clear teh 4 inch flowmaster collector in my qtp y pipe, and now the ground clearance has become more of an issue, I didn't think that 3/8 of an inch would matter, but I have bottomed the spohn cross brace out more than I care to remember. Could you try to get a couple more pics of the mounting to the floor, I am curious to see a couple different angles of that, looks like the brace "wraps" around the floor board in that pic.
Old 12-10-2004, 11:11 AM
LS1Tech Co-Founder
The brace is contoured to fit up in the transmission tunnel.
Old 12-12-2004, 02:39 AM
BLASTER's Avatar
How much does the piece weigh? It's got to be lighter than stock but just curious. Thanks.
Old 12-12-2004, 08:32 AM
BradWS6's Avatar
I've used this torque arm for 3 years now. I have an x-pipe and duals. The clearance is great. I had to fab a drive shaft loop. It doesn't come with one. It's a really nice piece.
Old 12-12-2004, 10:27 AM
Slow Z28's Avatar
Why do you have to remove the center console? i guess i am just not seeing everything. anymore detailed pics? just looks like the crossmember bolts up where that brace normally bolts up to. kinda like how the spohn is. torque arm just mounts to the brace and then the brace to the floorboard in that original location? what am i missing? thanks guys.
Chris
Quick Reply: FLP----Alston Torque Arms???
