FFHP 347ci Long Block
Suspended Sponsor Account
FFHP Forged 347
LS6 Block
LS6 Stock Crank
Diamond Forged 3.905 Pistons (Flat Tops 2cc Reliefs)
Diamond Pro-Select File Fit Rings
Eagle 6.125 Forged Rods with ARP 2000 Rod Bolts
Federal Mogul Main Bearings
Federal Mogul Rod Bearings
Clevite Cam Bearings
ARP Main Studs
Block is honed using a BHJ torque plate and decked using a BHJ block tru fixture. Block is line honed with ARP main studs. Rotating assy is balanced. Bearing clearances checked, rings file fit to application, oil galley plugs installed.
Also included:
Ported LS6 Oil Pump
Roll Master Heat Treated Double Timing Chain
Custom Cam
Comp Cams Roller Lifters
LS6 Valley Pan
Stage 2 6.0L Heads w/72cc chambers(we can mill the heads to provide the desired compression or use a different head setup if desired)
This setup is designed for low boost(6-12psi) FI or N2O
All for $5799.00(plus shipping) no core required!
Lead time about 1 week!
LS6 Block
LS6 Stock Crank
ARP Main Studs
Also included:
Ported LS6 Oil Pump
Custom Cam
LS6 Valley Pan
Originally Posted by A3Z28
different types of pistons avail for a different (non fi setup?) dang good price for a ready to go setup.
diamond recommends their line of nitrous/blower pistons if you run much more than 12 lbs of boost. theoretically you can run more boost but to C.O.A. we like to say what diamond recommends. what someone else does is up to them.
11 & 7 Second Clubs
Originally Posted by ForceFed HP
FFHP Forged 347
LS6 Block
LS6 Stock Crank
ARP Main Studs
Also included:
Ported LS6 Oil Pump
Custom Cam
LS6 Valley Pan
LS6 Block
LS6 Stock Crank
ARP Main Studs
Also included:
Ported LS6 Oil Pump
Custom Cam
LS6 Valley Pan
Originally Posted by bickelfirebird
Brad, I have a NO2 street car and am very interested in a longblock w/11:1 c/r. What type of warranty are you offering if you ship the motor to me?
Originally Posted by Blown 98 Z
Brad I am also interested in this, how long will this offer run?
Thanks, Don
Thanks, Don
Originally Posted by mike#9
What kind of power can be had out of one of these motors...set up for spray (internal strength)......but geared towards N/A in terms of heads and cam choice?
