FFHP Stage 2.5 5.3L Heads Introductory Special
Suspended Sponsor Account
Well folks here it is we are now doing Stage 2.5 5.3L Heads!
Heads will include the following:
Fully CNC'd 5.3L Heads
Hand Finished
Bronze Guides
Larger Valve Seats
2.055 REV Intake Valves
1.60 REV Exhaust Valves
Patriot Dual Gold Series Springs
Titanium Retainers
Super 7 Locks
Hardened Spring Seats
Flowed with Sheet
Milled up tp .030 if desired
Each set is meticulously inspected and check during every phase of the process. All spring heights and seat pressures set during final assembly. Ports are fine tuned to acheive maximum flow and velocity with smallest volume possible.
And as always 1 year parts and workmanship warranty!
Price is $1545.00 shipped (to the lower 48)
Price is good until 2/28/05
Hand Finished
Bronze Guides
Larger Valve Seats
Titanium Retainers
Super 7 Locks
Flowed with Sheet
Hey Brad, I've been emailing you back an forth about doing a set for me but with Manley 2.00/1.55 stock size valves. I noticed this is a stage 2.5 and we talked about a stage 1. What is the difference-from what I can see it's just the valve sizes. Is there anyhting else that's different? Also what is the turnaround time? Talk to you tomorrow-thanks!
Originally Posted by matts22
Do you have a flow chart for a typical set of these?
Lift intake exhaust
.100 71cfm 64cfm
.200 148cfm 119cfm
.300 215cfm 161cfm
.400 256cfm 199cfm
.500 289cfm 219cfm
.550 299cfm 228cfm
.600 311cfm 235cfm
as flowed on a SF600 with a radiused inlet and a 1 3/4" pipe on the exhaust 3.905 bore
Intake port volume is approx 229cc
Exhaust is is approx 84cc
Combustion Chamber is approx 62cc
Originally Posted by 69_YENKO
are they sold out right, no core/exchange charge?
Originally Posted by 98sspullin'em
those are some really good numbers and at a killer deal!!
and can you shoot me a pm with the flow #'s for the stg 3 ls6 heads? thanks
Originally Posted by JF WS6
Do you guys have any dyno results from these at all? Just wondering how they've done on different set ups.
http://www.ffhp.net/Camaro_Drag_Vid.htm
give it a few seconds to load, focus is blurry for a few monents(needs editing), we are in the left/inside lane
Originally Posted by ForceFed HP
no dyno results, how about track times though. we went 11.43 at 122mph with the early version of our Stage 2.5 5.3L heads. check it out here
cam was a 232/238 .575/.585 110LSA+2, car is an M6. race weight about 3400lbs
here it is at idle http://www.ffhp.net/CamSS_Vid.htm
