Lme 454" & 440" Ready To Go!!
LS1TECH Sponsor
LME has one 454" LSX and one 440" LS7 shortblock ready to ship!!
Parts Combinations are as follows:
454" LSX
* GM Bow Tie LSX block w/ billet main caps, priority main oiling, 6 bolts per cylinder
* Callies Compstar 4340 4.125” stroke crankshaft 24X (balanced to ¼ oz. in. tolerance)
* Callies Compstar 6.125” H beam connecting rods w/ ARP 2000 7/16” bolts
* Wiseco 4.187” custom forged nitrous pistons w/ lateral gas ports & tool steel pins 11.7:1 comp. w/ 70cc head
* Childs & Albert Fire Power top ring, Dura Moly second, .043” .043” 3mm (for reduced friction & high heat applications)
* Clevite MS 2199 H main bearings
* Clevite CB 663 H rod bearings
* Dura Bond one piece cam bearings
* ARP main studs
Capable of 300+ N2O shot
Custom LSX 454 cid. short block is $6499
440" LS7
* GM LS7 aluminum block w/ steel caps
* Callies Compstar 4340 4.100" stroke 24X (balanced to ¼ oz. in. tolerance)
* Callies Compstar 6.125" H beam rods w/ ARP 2000 7/16" bolts
* Wiseco 4.135" custom forged flat top pistons w/ LS7 VP's -3cc
* NPR stainless chrome rings 1.2 1.2 3mm (for reduced friction & high heat applications)
* ARP main studs
Custom 440" LS7 shortblock is $5999
Your LSX block is fully deburred, inspected, machined for rod clearance, line honed w/ ARP main studs, decked w/ BHJ deck true fixture, bored on 3 axis CNC, honed w/ torque plates to proper finish diameter for specific application, meticulously cleaned and final inspected. During assembly, bearing clearances & ring end gaps are adjusted for specific application.
Feel free to ask any questions.
Bryan Neelen
LME
713-849-4505
454" LSX
* ARP main studs
440" LS7
* ARP main studs
Bryan Neelen
LME
713-849-4505
Great company to work with, Bryan knows the meaning of customer service. For the money the shortblock is amazing. My tuner looked at the invoice and was flabbergasted that they could sell it for that, knowing that LME is a quality shop.
I must have called Bryan 100 times with stupid questions and concerns and he was always friendly and patient with me.
Bobby
Bobby
I believe that L92 heads would bolt up to the 454 LSX short block.
What style head would I use on the 440 LS7? Would an L92 head bolt up here also? Or does it have to be an LS7 head?
This might be a stupid question, but I am not familar with the interchangability of these 4th gen engines.
LS1TECH Sponsor
The L92 will bolt right up to the 454" LSX and the LS7 440"
LME is currently building a 454" LSX with unported L92 heads. It will be interesting to see the results with big cubic inches and a unported cylinder head.
LS1TECH Sponsor
454" LSX
* ARP main studs
440" LS7
* ARP main studs
Bryan Neelen
LME
713-849-4505
454" LSX
* ARP main studs
440" LS7
* ARP main studs
Bryan Neelen
LME
713-849-4505
454" LSX is sold.
440" LS7 is still available.
Thanks for the inquires.
I predict a boatload of low end torque, and very low HP, should make a killer stop-light to stop-light.
Bryan, since you're able to substitute a custom low comp piston for boost on the 454, could you also add 1 more cubic inch so I could call it a Pontiac
Killer price on the 454 shortblock, we will be ordering one very soon,
Ed
LS1TECH Sponsor
Ed
Ed
We look forward to doing business. Give me a call when you are ready.
Thanks,
Bryan
LS1TECH Sponsor
454" LSX
* ARP main studs
440" LS7
* ARP main studs
Bryan Neelen
LME
713-849-4505
454" LSX
* ARP main studs
440" LS7
* ARP main studs
Bryan Neelen
LME
713-849-4505
Thanks,
Bryan
LME
713-849-4505
440" LS7
* ARP main studs
Bryan Neelen
LME
713-849-4505
* ARP main studs
Bryan Neelen
LME
713-849-4505
A photo update.....
It has an ADM PERFORMANCE CNCed L92 top end kit with a custom grind with 240ish and .670ish on a 114.....should make your motor REAL HAPPY.....
i'll post up future updates with a graph and time slip and thanks again for all your help brother.....
you guys keep up the good work and the WARHAWK block looks crazy bro......i think Pat (Quality Motorsports) was saying he had one coming for a customer....can't wait to see that monster.....
Pat
nice to talk to you again bryan.....
here's the dyno brother.....this motor is gonna be a blast.....keep up the good work brother!!!!!!!!!!!
motor on 26 degrees with about 97 octane and 100 shot with a nitro dave truck plate......
