Water Methanol Injection Systems - Fully Assembled, Pre-Wired & Tested Ready To Go!!!
Attention LS1Tech Members
Mention this post and receive FREE shipping on any rear trunk mount Stage or Stage 2 Water methanol Injection System.
Benefits Include:
AIS Stage 1 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System $369.99
AIS Stage 2 Digital Progressive Trunk Mount Water Methanol/Alcohol Injection System $599.99
All trunk mount systems not come fully assembled, pre-wired and tested. Additionally, systems are now shipping with black anodized fabricated aluminum tanks straps replacing the previous rubber hold down straps and brackets.
All systems come standard with high temperature polyethylene hose and quick connect push lock style fittings. Now available, fully assembled stainless steel braided hose kits. This replaces the entire plastic fluid line with -4 heavy duty braided stainless steel hose with AN blue anodized fittings. This is the same style line used with nitrous injection systems with the exception of a change to the inner jacket to make it fully compatible for use with 100% methanol.
Upgrade any rear trunk mount system to stainless steel for an additional $109.99.
For questions about water methanol injection or help choosing the right system for your application email us at info@alcoholinjectionsystems.com or for immediate assistance you may reach us at 1.801.447.2559 during normal business hours.
Benefits Include:
- Lower air temperatures by 50-200+ degrees
- Reduces cylinder temperatures by 200+ degrees
- Reduce and eliminate engine damaging detonation & pre-ignition
- Increase 87-93 octane pump gas by 10-20 points
- Cools and protects the tops of your pistons
- Longer more stable combustion expansion and progression
- Allows you to safely run more boost and timing without the onset of detonation
- Removes and prevents carbon build up on pistons, valves and combustion chamber
- No need for expensive racing fuel or additives
If your looking for a great deal on a water methanol injection systems be sure to check out our group purchase listed here on the forum. Only good till the end of the month.
https://ls1tech.com/forums/showthread...light=methanol
Our special is wrapping up at the end of this month. If you've wanted a fender mount water methanol injection system this is a great opportunity to get in on one of our under the hood fender/firewall mount systems.
Have questions or need help, give us a call directly or post your questions here.
Stage 1 is non-progressive. Stage 2 is a tuneable progressive system. For more detailed information about our products please see our website which describes each system. If you have any other questions lets us know how we can help.
www.alcoholinjectionsystems.com
It really depends on the application and the type supercharger or turbocharger and so many other factors. Email me directly at rodney@alcoholinjectionsystems.com and I can go over this with you and find out more information about your application.
