could i add a louder horn to my stock alarm?
could i add a louder horn to my stock alarm? my alarm isnt very loud if it is going off, so i was wondering if i could just change out the horn or beeper or something? has anybody done something like that before?
TRAIN HORN! I promise you it sends them running (NEEDING NEW PANTIES).
I have that on my truck! The thiefs stole my system 12 hours after I installed it. They will not get the next one. I also have a set of them hooked up to my shops security system. You can hear almost 2 miles away.
Last edited by WhiteBird00; 01-21-2009 at 07:53 AM. Reason: merge consecutive posts
Ungrounded Moderator
Yes, you can install a louder horn - it's just the same horn that you blow from the steering wheel so just about any aftermarket horn you can fit in the car will work. I wouldn't recommend using those air horns that have no air tank because the spool-up lag of the compressor will make them ineffective for the timed honking of the alarm system. The train horns require a fairly large air tank that would be difficult to mount on an f-body.
