Any sponsors on here sell Car PCs?
i've looked into them you are going to want to build it yourself, or use a laptop. unless you have extreme $$$ to put into it. but to be fair they will do a lot more than the $1500-2000 headunits you can buy at audio stores.
This all started after my car was broken into and my in dash DVD/etc. got stolen two weeks ago. I wanted to replace it with something harder to steal...
Hmmm... in that case I will probably offer them for sale as well since I found a guy who makes them and I can just be a distributor for him. Probably offer a basic one with screen for $700 and $500 without but will also offer add-ons (GPS, an AI I am having made, etc...).
buddy of mine used to be an installer and that was what we talked about was that he didnt think it would be like a quality head unit with the correct pre outs, i dont have anything crazy but i have a eclipse 12 and 2 xtant amps pushing the sub and door speakers
There are a couple things you can do for the sound, you can get an external sound card and you can plug the RCA's into that, or you can get one of the rca to microphone plug adapters and use that, i have my carpc running off a sound card, works great. Also for the "on" wire to the amps i cut into my yellow ign wire of the radio harness, wired up a switch, because you can get some thumping if you have it wired directly, because the carpc will take about a minute or so to load and you want the amp to turn on after the PC is loaded up.
Audio will be taken care of by using mini din to male RCA adapters. the adapters plug into the sound card and the Then your RCA's will plug into the adapters to your amplifier. or you can run them to a Line driver to up the pre-out voltage.
Sound quality is great if done correctly. i could tell no difference going from my Denon headunit to using my car PC as a source unit
Brought this back since I'm reconsidering doing this in the summer and have been researching a little more. What you could do, and what I would do, is get a used laptop for cheap on craigslist or ebay and use a power inverter for it. Simplest way, cheapest (at least if you buy a laptop with a broken screen), and the best. At least, its best in the fact that you can have the carputer so to standby instead of hibernating or shutting down with ignition off because it has its own battery for power. Then when you run into a store or even in the next couple days, instant use instead of waiting for boot up.
And as far as sound you can get a usb 5.1 sound device for about $25 (or sound card if desktop) that will sound good and have rear and front out. Then you use an adapter that converts 3.5mm to left and right rca.
The only problem with that, which is what i initially did was how you power it initially when you get in the car, there were some people who soldered wires to the power button and extended it to where they could push it on when they got in the car but for me the solder points kept breaking so i said F-it.
Closed ex-Sponsor Account
Car PC's are awesome. I am building one right now for a magazine feature C5 Corvette that will be running live HP tuners to help control the 1100 RWHP
Watch the screens cause some wont work with certain operating systems.
Also, many have wakeup on lan so you can buy or make a module that sends a signal through a telephone cable to your computer when ignition turns on.
If not you can buy a docking station which has a power button you can wire. Problem with this is they cost from $15 to hundreds depending on what model they are for.
The main problem with inverters is people have claimed they create noise in your sound system. However, I would think if you isolated it in our spare tire well it wouldn't, I would think. An amp's power wire can too if not placed well.
this is what I would like to get when I get a double din bezel for my camaro
http://www.galleongps.com/product_details.php?id=17
loaded with a full PC
