Security light next to speedo prevents me from starting the car
I have an aftermarket security system that the previous owner put in, much to my chagrin. Its the kind where you put an extra key into an extra socket they installed below the steering wheel.
Car won't start until I wait a while and try it a couple of times.
Has anyone had this problem?
the chip might be getting worn or fitting loose. You might want to check the manufacturer and give them a call with your issue.
This happened to me one time and i had the key chip replace and everything worked great.
re:
The light, right next to the chip, is green, but the security light on the dash is lit up. If the chip says its green then I don't think the chip itself is at fault.
thanks anyway.
thanks anyway.
Ungrounded Moderator
The light on the extra key holder only indicates that there is a completed circuit... not that the correct resistance value is being read.
You can find plenty of information about fixing and/or bypassing VATS in this forum by doing a search on "VATS".
or you can also go change the chip to match your vats resistance.That is always an option. Or have the chip rewire to only affect power to the starter or any other component instead of your ignition or vats.
that God forsaken light has been the vain of my existence for years i hate that thing it would come on like 10 times before my car would start and in 95 degree heat i would almost just wanna leave the damn car. easiest fix ever though..... buy a resistor the same resistence as the pellet in your key unplug the wire going to the bcm and stick the resistor that was now bent to a "U" shape and slide it in the end of the plug and presto you are up an rolling no problem best .05 i ever spent!!!
is there an easy way of disabling this security feature?
I want to be able to start my car without this security thing going on all the time.
is there some fuse I can disable it with?
thanks
Pascal
thanks
Pascal
