Power seat problem
Power seat problem
my friend at the shop called me tonight and said my power seat isnt working. it wont click pop or make any noise or do anything. if the motor was bad woudnlt it try to do something? cant find any threads searching here or google. could it b a blown fuse or is the motor completely fried and needs replacing?
thanks ahead of time. i get the car back saturday and the seat is a little closer than i want (fat legs hahahahahahahahaha) jk
Ungrounded Moderator
It is almost certainly not the "motor" since there are three motors in the seat and it is unlikely all three could fail at the same time. It is possible but unlikely that it is the seat switch for the same reason (there are actually three switches in the housing). The power seat is protected by the DEFOG/SEATS 30-amp circuit breaker in the dash fuse panel (slot #12). Circuit breakers are difficult to test and tend to fail with age so replacing with a 30-amp fuse will likely solve the problem.
My seats decide when they want to work, you may not have the same problem but just give it a day and try moving it again. my seat one minute will work perfectly fine while the next minute the switches are completely dead
sometimes if you tap on the motor housings that will free up the internals
in the motors and get the seat to move again . over time the grease in the
housings get hard causing the motor to seize up . i also seen it happen with
cars in extreme cold weather .
