Can I use two brands of sound deadener?
I am in the process of installing Hushmatt in my Bird. Ian sent me 39sq ft. I ended up going kinda nuts with it and I am using way more than I thought i would. I used a bunch in the trunk area and quarter panels. Pretty much the driver side of the car is done minus the door. I am going to need another two boxes.
I talked to Dennis at Double D Mods when I ordered my bezel and told me about Raammatt. Hushmatt is 160 or so for 39sq ft and the Raammatt is 90. I can't really afford to drop 320 on just sound deadener.
If I do the rest of the car in Rammatt will there be any noticeable difference?
I don't have anything to compare it to but the Hushmatt is super easy to work with. No fumes, easy to cut and work with.
Thanks.
J
Thanks.
J
I've seen comments on other forums where people say they think Raamat and Dynomat come off same conveyor, just a different logo printed on the foil. I've never held them side by side, though. It's insulation, get what you can afford. Any is better than none.
I finally got the Rammatt a few days and I started putting it in tonight.
I definately like Hushmatt better. The Hushmatt seems to be a little thicker and is much easier to work with and easier to cut.
On the Rammatt the actual materiel is thinner and is very stringy.
Obviously I have no input on the actual performance of the two. Unless each side of the car sound different I am sure I won't know
I wish I had been able to buy Hushmatt again but that didn't work out. However the Raamatt cost 1/2 what the Hushmatt does.
