Gauge Cluster Bulbs
Old 08-03-2011, 12:44 PM
JaxJags's Avatar
Default Gauge Cluster Bulbs
I just bought a 94 Camaro, and the bulbs on the gauge cluster don't work. So I tried replacing them and they still didn't work. I put the dimmer switch all the way up, and I tried replacing the fuse, and they still don't work. Can anyone help me?
Old 08-03-2011, 06:44 PM
JaxJags's Avatar
Would reverse glow gauges do the trick?
Old 08-03-2011, 06:55 PM
trans_am7935's Avatar
it might be the motherboard itself in the cluster that died. new cluster would fix that. also could be a bad ground to the cluster or a bad switch for the dimmer/dome light. does the dome light turn on if you turn it all the way up?
Old 08-03-2011, 09:00 PM
JaxJags's Avatar
The dome light does turn on when I put the dimmer switch all the way up. The service engine light works, as well as the brake and others that turn on with the car.
Old 08-03-2011, 10:21 PM
Save the manuals!
wssix99's Avatar
Do the other bulbs (like on the HVAC panel) work and dim when you move the dimmer switch?
Old 08-04-2011, 09:49 AM
JaxJags's Avatar
They don't work either.
Old 08-04-2011, 10:41 AM
Save the manuals!
wssix99's Avatar
You may have a bad dimmer switch. "All the way up" is a separate function vs. the dimmer wheel.
You should be able to jump some wires at the switch to confirm if the switch module is at fault.
Old 08-04-2011, 12:27 PM
JaxJags's Avatar
Alright. I'll try that. Thanks
Old 08-05-2011, 01:55 PM
JaxJags's Avatar
Jumped the two outside wires, and it now works. Thanks wssix99.
Old 08-21-2011, 10:30 PM
Alpinestar99's Avatar
i am having this same exact problem! what do you mean by jumping the wires?
Thanks
