Alarm keeps going off...
Old 09-07-2011, 07:42 PM
ReApEr75's Avatar
Default Alarm keeps going off...
My alarm keeps going off for no apparent reason. It has got to the point where I had to disconnect the battery. I would hear my alarm going off continuously and then I would press the lock button and it would lock my doors and put the alarm on (not going off, just the lock alarm noise). Then about 1-3 minutes later it would just go off again and this repeated about 7 times until I got fed up and disconnected the battery. Anyone have any idea what is going on?
Old 09-07-2011, 09:38 PM
bad_408_vert's Avatar
Remove the shock sensor, its hanging from the harness by the spare tire area.
Old 09-08-2011, 02:46 PM
ReApEr75's Avatar
Thanks. Does it have to "reset" after disconnecting it?
Old 09-08-2011, 04:05 PM
No you shouldnt have to if you aren't putting it back.
Old 09-08-2011, 09:53 PM
'00_Z's Avatar
Mine sounds every 15 seconds or so when I use the remote to lock it. I'm gonna have to try removing the sensor and see if that works..
Old 09-23-2011, 10:27 PM
xBrandonx's Avatar
Adjust the sensitivity. It's in the hatch near the tire, it has a little white **** on it.
Old 10-10-2011, 03:09 AM
2manyprojects's Avatar
So the alarm still works without the shock sensor?
Old 10-10-2011, 07:46 PM
zbugger's Avatar
I had to disconnect my shock sensor at around 3 am one morning. Alarm kept going off. I adjusted the sensitivity to no avail. I just unplugged it and all's well. And yes, the alarm still works.
