Need Help with wiring to power window switch 99 Ls1 Camaro
Old 05-12-2013, 09:47 PM
Kevin_Ls1's Avatar
Default Need Help with wiring to power window switch 99 Ls1 Camaro
I have a 99 ls1 Z28.. Just bought the car from a friend of mine. took door panel off of driver side door to fix the rod that connects to door handle.. anyways I noticed when I took the panel off I saw two wires disconnected from the power window switch one wire was a light tan color and the other I believe was blue, I cant remember til I re check tomorrow.. but what part of the switch would those two wires connect to? Anyone know off hand or have a wiring diagram for those power window switches? Thanks guys I greatly appreciate any help.
Old 05-13-2013, 05:46 AM
Save the manuals!
wssix99's Avatar
pics?
Do the wires have metal pin grip terminals on the ends of them?
Old 05-13-2013, 07:26 AM
Ungrounded Moderator
WhiteBird00's Avatar
Light blue and tan wires are the connections on the driver's side to control the passenger's side window. Light blue goes on pin B and tan goes on pin C of the window switch. The wires go across the car to pins B and E respectively on the passenger's window switch.
Old 05-13-2013, 08:11 PM
Kevin_Ls1's Avatar
its a light tan wire and grey wire that's disconnected from the switch.. the ends of them used to have the metal contact but it appears they broke.. I know I can solder them back on, I just dont know where those two wires connect to on the switch..
Old 05-13-2013, 08:40 PM
Gray wire goes from pin E on the switch to the express down module on the firewall.
Old 05-13-2013, 08:56 PM
Save the manuals!
wssix99's Avatar
Are the original terminal still in the connector body? If not, I have the P/N for new ones.
BTW - You'll want to use crimp connections. Solder joints are brittle and can break/spark due to the vibrations in a car.
Old 05-13-2013, 09:53 PM
Kevin_Ls1's Avatar
yes the original 2 terminals is still in the switch body, for what would be for those two wires.. I want to solder them in but what if I hooke them up reversed? is it it labeled on the actual switch for where those two wires supposed to go? Im not sure as I wasnt looking out for that.. Thanks guys for the quick responses, I greatly appreciate it
Old 05-13-2013, 11:54 PM
Save the manuals!
wssix99's Avatar
The letters Whitebird00 gives above should be embossed in the connector body.
Soldering two wires together on a car is potentially dangerous, so you'll want to crimp the wire that's left on the terminal to your loose end.
Old 05-14-2013, 05:38 AM
Kevin_Ls1's Avatar
Yes im sorry your right last thing i need is a fire.. so grey wire would be connected to terminal "E" on switch and the tan wire would obviously be the last one thats availble right? Im I understanding this correctly guys? Thanks again for all the help, you guys rock!
Old 05-14-2013, 07:37 AM
Save the manuals!
wssix99's Avatar
Yes. Whitebird00 pointed out that tan is "C", above.
Old 05-14-2013, 09:54 AM
Kevin_Ls1's Avatar
Oh ok lol.. I miss read it.. I see it now.. I'm going to tackle this project later and I'll post up the end result.. Thanks again everyone for the help.
Old 05-18-2013, 10:11 PM
Kevin_Ls1's Avatar
Thank you to anyone who replied and helped me out on this one.. I reconnected those two wires with connecters (not Solder) and it is working, but I will add the fact that I do indeed need a new switch as its seen better days.. and I also need to invest in getting a new power window motor for the passenger side because that one does not work at all. other than that things are looking up and I thank each and everyone of you who replied. Thank you
Quick Reply: Need Help with wiring to power window switch 99 Ls1 Camaro
