HELP! I want to replace broken antenna but Part #10425535 is no longer available...
Old 05-26-2015, 03:43 PM
MSTZ TA's Avatar
Red face HELP! I want to replace broken antenna but Part #10425535 is no longer available...
I've ordered from several places, only to have them email me that it's not available.
Is there another bracket that has worked for anyone? Or another option?
Thanks!
Old 05-26-2015, 08:43 PM
infinitebird's Avatar
Might check in the parts section on here or a local junkyard. If you just need the bracket you should be able to get one off any car. You can get a new antenna at auto zone. I did that but reused the stock bracket since the bracket it came with wasn't as good a fit.
Old 05-26-2015, 10:49 PM
MSTZ TA's Avatar
Thanks for the reply. I've thought about checking a junkyard. I rarely listen to the radio but have forgotten, twice now, to power off the radio when going through the carwash and it was broken. Figured I'm safer with a stubby one. And I rarely go through carwashes! I ordered one on EBay but need a bracket yet.
Old 05-27-2015, 06:35 AM
Save the manuals!
wssix99's Avatar
You should be able to ask for the part off a Camaro. I recall that they all came with a fixed antenna.
Old 05-27-2015, 03:56 PM
MSTZ TA's Avatar
I tried 2 auto salvage places here, but no luck. I found this site called SeekAutoParts.com, what a joke. You input what you're looking for and within minutes I had 3 calls, from Indian men, saying they had the antenna but would not sell just the bracket. They wanted $75 and up. Yeahhhh, ok.
Old 05-27-2015, 07:04 PM
Another option is to post in the WTB section.
This guy found one: https://ls1tech.com/forums/parts-wan...a-bracket.html
Old 05-27-2015, 09:15 PM
Copy & Paste Moderator
VIP1's Avatar
Is it just the bracket? You can probably make a replacement.
Old 05-27-2015, 10:42 PM
blue09rocket's Avatar
Im going to a junkyard or 2 close to me for other reasons, but while Im there ill check for an antenna bracket, I live in Hanover so not far from you.
Old 05-27-2015, 11:24 PM
MSTZ TA's Avatar
That would be awesome, thanks!
Old 05-27-2015, 11:25 PM
MSTZ TA's Avatar
Yes, for the quick fix, but my friend who will be doing the work, may be able to make something, if we can't find the bracket.
Old 05-28-2015, 10:32 AM
MSTZ TA's Avatar
Looks like 97ramsst is able to hook me up with the bracket! Thanks for the guidance, everyone!
Old 05-28-2015, 01:05 PM
that's good, every yard I went to today either the car had a power antenna or the antenna bracket wasn't there.
Old 05-28-2015, 01:14 PM
Save the manuals!
wssix99's Avatar
Dos you try one of the yards that specialize in F Bosy cars, like Cleveland Pick-a-Part?
Old 05-30-2015, 11:51 AM
MSTZ TA's Avatar
So that GN part wasn't needed afterall. My friend took the power unit out and cut the line from it. We got a "universal" antenna at AutoZone. It wasn't universal though, because it only came with a male end and since we have the male end of the antenna, that wouldn't work. He cut the female end off power unit and spliced to universal line. Plugged into my antenna line and it worked!! So glad!! Thanks for all the replies to help!
Old 05-31-2015, 03:55 PM
I had the same issue, you can also get the Metra 40-UV41 adapter which is a female to female.
Old 06-01-2015, 10:39 AM
MSTZ TA's Avatar
We were looking for a Fe - Fe adapter but of course wanted it right then and AutoZone didn't have it. Thanks!
Old 06-02-2015, 09:42 AM
MSTZ TA's Avatar
You don't need it. We used a universal antenna, which has the base for the antenna and then spliced the end. But infinitebird stated below that you can get a Metra 40-UV41 adapter which is a female to female, so no splicing needed. I'm just waiting for my stubby antenna to come but the universal one isn't too bad.
Quick Reply: HELP! I want to replace broken antenna but Part #10425535 is no longer available...
