Best sailpanel subs for TA with Pioneer AVIC D3
Best sailpanel subs for the money for a 2002 TA with the Pioneer AVIC D3, looking for a low/mid price, something descent.
Some of the stats from the OM are...
Max power output 50 W x 4 + 70 W x 1 for subwoofer ch/2 ohm
Frequency 50/80/125 hz
Thought these might be worth a look?
(non-sponsor link removed) BOSS Audio NX654 Onyx 400-watt 4 way auto 6.5" Coaxial Speaker
If your TA has the factory Monsoon then it DOESN'T MATTER what radio you have in it as the power to the subs is provided by the Monsoon amp.
either way you DON'T want a Coaxial speaker like the one you linked anyway in that location.
Alright I guess we know I don't know speakers...
How about...
(non-sponsor link removed) Pyramid W64 6.5-Inch 200 Watt MidBass Poly Woofer
or
(non-sponsor link removed) Planet Audio TQ622 6.5-Inch 2-Way Poly Injection cone Speaker System
Is the DVC a must or real good for the sail panel subs?
How about...
or
well if you want to get the full power from the monsoon amp you need the dual voice coil, with only 1 voice coil you can only use 1 of the 2 sets of wires back there, outside of that the Pyramids are the only ones that are even the right type of speaker for that location. Just remember you get what you pay for and those are sold indiviually so you need 2 of them and by that point your very near halfway to the cost of the bazooka's from DoubleDMods or KeeAudio which are universally considered far better then the brands you've listed so far and are actual dual voice coils, I know some people have found some Pyle DVC 6"'s that they've used as replacements, I don't know the exact model number, but it's similiar in price to the brands you are listing and is considered a cheap replacement option, personally I would fork up the extra cash for bazookas.
NO 2-way, 3-way or 4-way speakers.
Ok, been reading...and a few seemed to like these, at least I think it is these...
(non-sponsor link removed) AUDIOPIPE TSV6R 6" 150W Car Audio Power Subwoofer DVC
I just want some good ones for the sail panels and save my $$ for the front door speakers
Ungrounded Moderator
I have used the AudioPipe subs in a Trans Am. They have come down in price quite a bit since then. They are a good fit with a Monsoon system and produce clean bass but they have been known to have build quality issues with the spider (the part the speaker cone attaches to) detaching from the frame especially if roughly handled during installation. The parts are only glued together rather than attached with screws. But if you are careful during installation and you don't push them too hard (too much volume) they sound pretty good.
Besides, as Daniel said, by the time you buy two of them you're more than half way to the price of a set of Bazooka subs that have been the go-to replacement subs for Firebirds for years now.
The factory configuration of the Monsoon system in a Firebird has two separate channels of low frequency signal from the amp to each sail panel sub so you need two voice coils to make use of both channels. You could use an SVC sub but then you could only connect one channel on each side, giving up half of the available power.
You will find that reading the Monsoon FAQ sticky at the top of the section will give you plenty of information about how Monsoon systems work and what can be done with them.
Yes, when you plugged in the new Pioneer head unit after using a harness adapter spliced to the HU (you DID use a harness adapter, right?), it connected the four channel output of the HU to the input side of the Monsoon amp located behind the quarter trim in front of the spare tire. The amp splits the signal into eight output channels and filters for the type of speaker mounted at each location - doors, sail panels and hatch area.
I used the harness that came with the avic (it was a used avic) but all speakers in the car have sound so I guess I hooked it up correctly, electric and wire hookup being my weak link...Thank you for all the input and I will read the stickies...some more...Thanks again.
You didn't happen to get it from VIP1 on this forum did you? If so, it was one I sold him a few years ago. It's an excellent head unit that works well with Monsoon systems because of the extensive sound customization options it offers.
I think you will be very pleased with how it will sound.
I don't remember where I bought it but it appears to have been back in 2011 and I have several PM's from VIP1, I looked through a few and did not see any mention of a sale, just asked him questions about the "KITT" display on his unit, anyway I have never been really pleased with the sound of the avic vs the monsoon, maybe that I have not messed with the controls enough as I just found the different "sound stages" if that's what you call then, my unit is set to off, I noticed that the 3 or 4 presets all added power and sound to the unit, so maybe after my speaker replacement it will sound better than the monsoon...maybe?
I did a speaker up-grade before I bought the avic and the hatch speakers still sound good (for them), the sail panel subs had dry rotted and have to be replaced, the door ones still sound ok but could be better, are there good replacements for the doors that won't make my wallet cry any more? Thanks for the help and is there anything else you can add?
Copy & Paste Moderator
6.5" component sets can vary widely in both quality and sound. Sound is often a personal preference. For example, Infinity makes components you could use and some people love them because they are "bright" (lots of treble) while others listen to the same speakers and call them harsh (the common quote is "they make my ears bleed"). Your best bet is to check out a local audio shop and listen to the speakers you're considering before you buy them. Other inexpensive brands you might consider are Kicker, Pioneer, Alpine and Polk. The CDT CL-61CV components from Kee Audio are very good if you can spend a little more ($150/pair). Stay away from Boss and Pyle.
Replacing the dry rotted sail panel subs will do wonders for bringing back that warm full sound that the Monsoon does well. You're fortunate with a Firebird in that there are no special requirements for the door speakers - just about any 6.5" component set will work. Camaros have the issue of needing component sets that mount the tweeter in the middle of the woofer limiting the available selection of replacements.
I went with the Polk Audio DXi651, was this a good choice?
Thanks for all the help!
