Question on re-wiring car from scratch.
Car is a 2000 Trans Am with factory Monsoon 10 speaker system. I bought the car a week or so ago and only the rear two hatch speakers worked. Long story short, car's audio system is completely fubar'd and gutted.
Here's my idea (for now): start from scratch and run a 6 speaker (door panels, sail panels, and hatch area) system directly from the headunit. The chances of me being able to reuse the Monsoon amp or factory stereo wiring are zero.
I've already ran new speaker wiring to both door panels. PO had already run speaker wiring to hatch area speakers.
QUESTION: How can I run power to sail panel speakers? There are only 4 speaker outputs from headunit, can I have right side sail panel/hatch area 'share' an output? How would I wire this? Sail panel and hatch area speakers are 4 ohms each.
Thanks.
Thanks.
Ungrounded Moderator
Before you do that, make sure your head unit is 2-ohm stable. Running pairs of 4-ohm speakers in parallel produces a 2-ohm net impedance at the head unit and not all of them can handle that. Lowering impedance creates more current flow which also creates more heat and some HUs aren't built to handle it. Most good aftermarket HUs won't have a problem (check the specs anyway) but factory units are known to fry their output sections when connected to too low a load.
This was brought up while talking to a buddy on another forum. I've decided to go the safer route and wire them in series, and then add some fade to make up for lower output.
