Camaro LED Brake Lights
Old 08-10-2004, 11:22 PM
LS1_SS's Avatar
Default Camaro LED Brake Lights
Ok dont get too excited I dont have them.... yet. Im starting the project tomorrow, and im going to need a lot of help, first of all anyone with any used 98-02 tail lights that want to sell them dirt cheap let me know, also if anyone knows a good place online to get some leds, im going to need about 200 of them just to be safe.
Also anyone who knows a lot about electrical shizit, is the stock power anough to run say 50 LED's?? Ive checked up and am pretty sure it will be fine since LED's use a lot less power than lights, and how many LED's can i use per resistor?? and what kind of resistors would be best??
Any info would be great, and when Im done if anyone is interested I will do a write up on it with some pictures and what not.....
Old 08-11-2004, 06:56 AM
1QUIKWS6's Avatar
BTW, they already make LED bulb set-ups to replace #3057 or #3157 tail light bulbs. There are around 20 LED's mounted in a housing that plugs right into your socket - come in clear or red. I replaced all (6) of my rear bulbs on the TA with these - six because I have the sequential turn signal mod with the xtra light to replace the outboard lamps.
Guy sells them on eBay for $9.99 or I've seen them in autoparts stors for $18
Old 08-11-2004, 09:49 AM
LS1_SS's Avatar
yes but those take up 1/20th of the tail lamp, i want the entire red area to be filled with LED's....
update... tried to take apart the tail lights last night, they wouldnt come apart for the life of me, ended up cracking one, so now back to original plan of cutting them.. anyone have any suggestions??
Old 08-11-2004, 11:07 AM
2FAST4U's Avatar
Sounds cool but. It would be easyer to do like the Cadillac DTS light and use one light and that plastic plate that makes it look like 200 leds. Then all you need is that plastic plate. Heat the lens in the oven to remove the glue and glue the plate inside the lens! The oven is the way they do the front lights!
Just a idea as it would be a pain in the *** to drill,glue,and wire 200leds. Unless you had a led board?
Old 08-11-2004, 12:48 PM
Copy & Paste Moderator
VIP1's Avatar
Check out this thread:
https://ls1tech.com/forums/showthrea...&highlight=led
Old 08-11-2004, 01:00 PM
LS1_SS's Avatar
i tried them in the oven but they wont come apart, one light started to melt so i hadto take them out and they still wouldnt budge... anybody ever try takin apart camaro tail lights before??
Old 08-11-2004, 01:07 PM
LS1_SS's Avatar
so how exactly does that volt calculator work?? i dont know much about the electronics
Old 08-11-2004, 10:45 PM
VIP1's Avatar
Here is an example:
Voltage = 1.5V, Amp = 0.015 A. Therefore, to calculate resistance needed for a 12V line-in;
Ohm = (Mains Voltage - LED Voltage) / LED Amperes, so;
Ohm = (12 Volts - 1.5 Volts) / 0.015 A
= 700 Ohms or 750 Ohms
(http://www.virtual-hideout.net/guide...us/index.shtml)
Here is a LED calculator. There are better ones, but this gives your an idea.
http://www.metku.net/index.html?sect...calc/index_eng)
The "amp" box in the calculator is already in miliamps, so enter 15 instead of .015
Here is another LED Calculator:
http://wolfstone.halloweenhost.com/T...d_LEDCalc.html
This one gives pointers when you use it.
The calculation also changes if you are doing a single LED or multiple. It also changes depending on whether you are running them in Series or Parallel.
Old 08-13-2004, 02:06 PM
Edrummr's Avatar
If I were to take on this mod, I'd shave the rear lights completely and put in a slit of LED's that continues along the rear deck seam like the BMW Z8. Shaving the tail lights would be intense but installing a row or two of LED's behind a strip of contoured and tinted polycarbonate should be doable. Done right, the results would be spectacular. Gotta love the Z8 tail lights.
Old 08-16-2004, 11:47 AM
InfiniteReality's Avatar
This statement is true as I just got done doing 196 of them to Illuminate my front bird. Worth it you ask?? Definitely, see pictures:
http://photobucket.com/albums/v375/I...tedFrontPlate/
18 LEDs is alot easier and WAY easy once you've already done 196 of them and know how to organize it better :
http://photobucket.com/albums/v375/I...nsePlateLight/
Old 08-16-2004, 12:19 PM
SMOKINV8's Avatar
Keep in mind that you'll need to wire up different intensity LED's in there somehow. It isn't just a matter of getting them to light up when you hit your brakes, they'll also need to light up when you turn on your lights and aren't on the brake.
Old 08-16-2004, 01:10 PM
VIP1's Avatar
Or you could create a pattern, such as just an outline for "parking light" mode and the whole thing can light up when you hit the brakes.
Old 08-16-2004, 09:59 PM
LS1_SS's Avatar
ok ive been through 100 LED's and thats just on one light!!! crazyness, but i think i might cut it down to fewer leds to each light, but it looks so nice, ill try to gets some pictures up soon, but im nowhere near being done yet
Old 08-17-2004, 03:31 PM
What would really be cool is if you can have a controller to do different running light pattern, brake light patterns and turn signal patterns. I bought a tail light board for my bike and have 30+ different patters for EACH of the above mentioned. Pretty cool little thing and would be awesome to have on a car. Not sure the legal aspect of it, like the running lights, but I've had no problems on the bike. Plus on bikes, you want to be noticed so many cops understand?
Here's 196 of them lit up. Sorry for the quality, crappy free camera phone.
