Wiring for the fog lights
I have a question about the wiring for the fog lights of my friends car, its a 95 transam. We are trying to get both fog lights to work. The problem is that currently only one fog light is connected with a set of two wires running to it, green and black I believe. Now I don't seem to find the other connector for the other fog light I don't know if the previous owner cutted it or what happen. So my question is how are both fog lights connected. Do you have just one set of wires that split in two to both fog lights coming from the same place or does each fog light has it own separate set of wires. Can anybody guide me as to where I need to look or know of some kind of manual that shows how the wiring should be. I really appreciate your help.
question about fog lights.
I have a 1999 z28 that did not come with factory fog lights. I have recently put factory fog lights in, to include the prewired switch on the dash. My question: I am not prewired under the hood for fog lights, aside from the big fuse that I need to purchase and install, what else do i need to do. Are these harnesses hiding somewhere? Where can I get factory plugs for the fog lights? What wires would I splice into? Does anyone have any wiring diagrams? Any help here would be appreciated.
Im sure the dealer will sell you factory plugs. Just wire them to the battery on a switch with a fuse. If you want them to come on with the head lights it gets a little more complicated. A use of a relay will solve those problems.
fog lights..
TTT. I priced the harnesses and they want way to much money. I was pretty sure that the camaro is 'prewired'. I have found this to be true for most accessories and options. However, I cannot find these plugs. Does anyone have any experience adding foglights to their camaros. Maybe this harness is hiding a little deeper than I imagined.......
