14.4V how?
Old 10-05-2005, 09:40 PM
zorrander's Avatar
Default 14.4V how?
I have been digging around seeing that most people's cars run around 13V on a normal drive... I've never driven a car until this one that didn't run at around 14V. Why do these things run so low?
Old 10-05-2005, 10:37 PM
redline2k's Avatar
could have a weak battery or dirty terminals.
might have a pulley on it.
guage could be off.
alt could be going bad.
etc. etc. etc...........
Old 10-06-2005, 03:09 AM
HiTechGent's Avatar
Most cars I've put a meter on run between 13.2 and 13.7 volts unless the electrical system is loaded down (or they have problems). If your looking at the battery indicators on the dash, I can see why you might expect >14V. As they are rather inaccurate.
Old 10-06-2005, 05:43 AM
NoTicketsPlease's Avatar
My escort radar detector shows 13.9-14.1 volts.
Old 10-07-2005, 11:27 AM
BJM
BJM's Avatar
Alternators usually have a temperature sensor inside them and when cold the regulator will put out a higher voltage. Check again when its really cold.
