Wiring from amp to monsoon HU.
Old 10-18-2005, 03:15 PM
99 bad aSS's Avatar
Question Wiring from amp to monsoon HU.
I'm going to be putting in a 10 inch sub in soon and was just wondering if the stock headunit has the hookups for the rca cables and remote wire already there or is there a wiring harness i will have to get.
thanks
Old 10-18-2005, 04:13 PM
LSfast1's Avatar
our factory monsoon radios dont come with rca cables but u can buy an rca adapter that has the rca plug ins. And for the remote wire. u can hook it to the pink wire. which is the power antenna wire. or you can hook it to the yellow wire. which is a 12v wire.
Old 10-18-2005, 04:57 PM
99 bad aSS's Avatar
where can i get a rca adapter? can someone post a link. and i don't think i have the keys to pull out the stock headunit is there anything else i can use?
Old 10-18-2005, 05:13 PM
joe_kool315's Avatar
pull the plastic surrounding the climate controls and head unit straight out and it's just 2 screws holding it in ...
Old 10-18-2005, 05:57 PM
Phoenix 5.7's Avatar
camaros don't have the pink power antenna wire.
Old 10-18-2005, 07:57 PM
99 bad aSS's Avatar
can anybody tell me where to find a rca adapter to the stock headunit?
i've been looking for a while and haven't had any luck.
Old 10-18-2005, 09:16 PM
i have one that a stereo shop installed in my car. PCA model SNI-15. it was spliced into the speaker wires for a signal and converted it to RCA. there are better alternatives, but this one worked good for me(i have a aftermarket now). think it was around 10
Old 10-19-2005, 08:50 AM
todddchi's Avatar
It is also an option to tap off the rear amp wiring (high level inputs).
Not sure if I would do this in a high end system, but with a noisy exhaust, and for only bass, I'd try that before anything else.
Old 10-19-2005, 12:58 PM
HavATampa's Avatar
Do a search for AOEM-GM21C. There a ton of post on this issue. Check http://www.logjamelectronics.com/ for the kit.
Old 10-19-2005, 01:59 PM
99 bad aSS's Avatar
thanks thats exactly what i needed
