Steering wheel control adapter
Old 01-31-2006, 10:26 PM
tylerdj's Avatar
Default Steering wheel control adapter
Where can I get the adapter to make my steering wheel
controls work with my aftermarket stereo? Thanks guys!
Old 01-31-2006, 10:31 PM
AbsolutHank's Avatar
PAC SWI-X
Look it up on ebay...they are cheapest there. They are universal. AFAIK, your HU has to be remote control ready.
Old 01-31-2006, 10:58 PM
j3ff's Avatar
u cant use em on Sony.
If u need help let me know
Old 02-01-2006, 12:56 PM
The Guz's Avatar
Yeah, the Pac- SWIX is the one to use. As stated, the adapter does not work on the Sony headunits because they use a different frequency. Our sponsor PFYC carries it.
http://www.pfyc.com/store/merchant.m...y_Code=CMOTHER
Old 02-01-2006, 06:54 PM
jsturdivant's Avatar
If you go to the Pacific accessory corporation site they have all of their steering wheel control devices. They list the PAC SWI-PS as a device that will intergrate with Sony HU's if they accept a wired remote. I've already contacted their tech support and you won't have to sacrifice your HU's remote to use this setup. Also you won't have to drill holes in your cup holder to put it in.
Old 02-02-2006, 10:14 AM
JasonWW's Avatar
Here's how I did mine. Hope that helps.
Works like a charm, even in direct sunlight.
Attached Thumbnails Steering wheel control adapter-steering-wheel-remote.jpg
Old 02-03-2006, 11:53 PM
_JB_'s Avatar
I don't know if they make them anymore, but Soundgate is the best. You don't need to run the IR eye anywhere and don't have to worry about reprograming it when the power is disconnected. A downfall is that IR remote becomes useless with it.
Old 02-04-2006, 08:34 AM
JasonWW's Avatar
Seeing as how most aftermarket radios use IR remotes, that Soundgate doesn't sound very usefull. What is it exactly?
OK, I found it, you mean SoundGate's REMOTE3?
http://www.soundgate.com/index.php?r...&usereferrer=1
How the heck does it work and how would it operate a PC?
Oops, thought I was on MP3car.com.
Old 02-04-2006, 10:08 AM
I'm telling ya'll the swi-ps is the way to go. It just plugs into the back of the HU. No fuss. No Muss. The IR remote can still be used, also. The only catch is your HU has to be able to except a wired remote.
Old 02-04-2006, 10:18 AM
JasonWW's Avatar
Yea, that's a big catch. My HU doesn't have a wired remote port. That thing looks about $114!
Is it really better than the PAC unit?
The PAC is nice also if you want to use the steering wheel remote to control a PC. That's what I'm doing.
One other thing, does the soundgate let you reassign the buttons?
I wanted my volume buttons on the left side and the PAC unit lets you do that. I don't know about the Soundgate.
Old 02-04-2006, 11:39 AM
Blacker's Avatar
The soundgate looks like a nice piece and rather expensive.
Old 02-04-2006, 02:01 PM
[QUOTE=JasonWW]Yea, that's a big catch. My HU doesn't have a wired remote port. That thing looks about $114!
Don't know if you were referring to the soundgate product or the Pac swi-ps, but I got mine for $50 from sonicelectronix.
Old 02-04-2006, 02:04 PM
JasonWW's Avatar
The Soundgate.
The Pac swi-ps is cheaper at least, but still limited. Can it's buttons be reprogramed or are you stuck with the factory button assignment??
Old 02-05-2006, 09:21 PM
_JB_'s Avatar
You can set different steering wheel controls with the PAC, not sure about the Soundgate though. The hookup is the same, except if you are running an Alpine or JVC it will be an easy plugin and no IR eye to mount.
I bought the PAC for my car, but during the install I came accross a Soundgate improperty wired from the previous owner. The part I didn't like about the PAC (and Soundgate) is that you had to run the IR eye somewhere, and I read posts that the eye can be a pain sometimes depending on where you put it at. Sometimes sunlight messes it up, sometimes it's people.
Soundgate pros:
Easy hookup, four wires
Always works with direct wire with Alpine and JVC headunits
Also has an IR eye
Don't have to reprogram
Soundgate Cons:
Not sure if you can reprogram the steering wheel controls
Price
IR eye can be obstructed
If "direct wire" hookup is used, the IR remote becomes worthless
PAC pros:
Easy hookup
Can program buttons to your liking
Cheaper
PAC cons:
Environment can affect it
Programing can be a pain
Have to be reprogramed if battery it disconnected from car?
Old 02-05-2006, 10:19 PM
the swi-ps is different from the swi-x the swi-x works with all HU's and uses an infrared eye to send signals to HU, but the swi-ps only works with pioneer or sony and is hard wired into the back of the HU. If you have an Alpine, Kenwood, or Eclipse you have to have a different version of the unit specifically for your HU. Either way, the important thing is that you have an option other than using an infrared eye setup. You can use one that hardwires into the back of the HU, if said HU excepts a wired remote.
Old 02-06-2006, 01:56 PM
JasonWW's Avatar
PAC SWI-X pros:
Easy hookup
Cheaper
Can be used with PC or almost any HU later on.
PAC SWI-X cons:
Programming is not that hard at all and only has to be done once.
Info is stored on chip and doesn't need power to retain data.
Old 02-06-2006, 05:56 PM
Senior Member
Country Boy's Avatar
I had the Soundgate with an Alpine HU and it did NOT work....
