HELP w/ shift light
HELP w/ shift light
ok installed a raptor shift light in my car seemed fairly simple power ,ground and tach feed. I read that the it should be connected to the #10 pin(white) which i did. Now it gets power , it lights up and tells me what rmps its set at and how many cylinders its set for but when it gets to the shift point the lights dont come on. Any ideas ,help would be a greatly appreciated.
thanx
thanx
Do you have the cylinder switch set correctly? You do NOT set it to 8 on the Raptor, you set it to 4.
Also, double check here:
http://www.raptorperformance.com/Chevrolet/camaro.htm
to make sure you connected to the correct wire.
