LS1 vs. LT1
LS1 vs. LT1
I have a 2000 T/A M6 with a lid and SLP Loud mouth. Im racing a 97 LT1 A4 with a intake, catback, 3:73 gears, and Midlenght headers. Were going to be racing in the quarter mile at the track. He wants to put money on it and was wondering what everyone thinks and how much you guys think I should put on it?
Dont mess up the launch and you should pull up top, but he will kill you out of the hole, if my 2.73 A4 LT1 would beat A4 LS1's out of the hole, he should get you, do 1/4 NOT 1/8!!!! (I used to pull LS1's to about 50mph or so, tehn they walked...)
Yeah, if he can hook he'll have a very strong charge, with those 3.73's and that deep 3.06 4L60E first gear.
What is he tuning with? Have you seen his car run?
If he is tuned but he has no cam, I think you will catch up to him before 1/4.
Jim
Jim
Lt1 Vs Ls1
You better be careful maybe he has a stall ? longtubes ,stall with gears he could touch 13.0's 12.90's . Don't know any one in my neck of the woods with an Lt1 calling out Ls1's.
Plus the 0-60mph times are way better for the Ls1 (upto a second better or so, depending on where you read). but by the 1/8 you should be pulling 80'ish.
Not saying it ain't true, but it doesn't add up to me.
Did the Lt1's have different internal gear ratio's that make it feel quicker off the line??
Originally Posted by 300bhp/ton
I don't get that. The Ls1 makes good low end grunt (more than a Lt1 to my knowledge).
As far as I know, the lt1 is the torque monster, easily taking most ls1's off of the line if it can get traction, but as far as top end it is no comparison, the ls1 is much faster at high speeds
it still doesn't add up to me.
I've just been doind a bit of looking and 5.7 seconds 0-60mph seems pretty common for the M6 Lt1.
Where as even a A4 with 2.73 rear LS1 will be low 5's (5.3), and I've seen 01+ M6's rated as low as 4.8 seconds 0-60mph.
Here's a dyno graph from a stock 99 Ls1 (found in the dyno forum):
As you can see the torque curve is very flat, so although the Ls1 makes PEAK torque high in the revs it is producing almost the same torque at just over 2000rpm. Even at 1500rpm it's still pretty damn impressive.
Anyone have a dyno graph for a STOCK Lt1, I really can't beleive it's producing as much torque as an Ls1 in the low rpms.
ok, in 1993 the 5.7 LT1 prodced 325lb ft @ 2400rpm, so yes the PEAK is very low.
But according to the dyno sheet above the Ls1 is producing 290lb ft of torque at 2400rpm. But that's at the wheels. I think it's fairly safe to say (assuming this dyno graph is typical of a STOCK Ls1) that a Ls1 would be producing as much or more torque than a STOCK Lt1 no matter the rpm.
I do agree a 3.23 rear compared to 2.73 will make a difference. But i doubt it can potentially over come what many consider to be 50-75bhp difference in STOCK output.
Originally Posted by kennyxg
No offense but how common are Lt1s in England?
Having said that, my mate who runs a paint shop has a Lt1 Corvette (93 I think) and a Lt1 Z28 (97) both auto's and both mildly modded.
Lt1 Vs Ls1
I'm not desputing the fact that Ls1s make more power , but dont you see thats the whole thing about it . My friend has an 01 Ls1 with the highway gears a4. But the vehicle will smoke the tires from a standing start. My Lt1 wont smoke the tires from the line it just takes off. There for out accelerating the Ls1 momentarily.Of course the Ls1 catches and passes the Lt1 without a doubt.Now there are some old Lt1s out there that aren't running to full potential and i'm not saying the Lt1s always get to 50 faster. Ls1 with drag radials stock for stock should put the Lt1 out with no problem.
I hear what you say, but by that logic an automatic Mustang 4.6 should also beat a Ls1 off the line because it doesn't spin the wheels.
Lt1 Vs Ls1
My old Lt1 has recorded 1.9 60ft on reg radials ,my 90 Mustang has gone 1.88 60ft on street tires . Driver has alot to do with it but the hell with fancy theory's it's when you start to apply the theory to action when you find you can't beleive everything you read.
Jim
Jim
