Removing TCS but keeping ABS and CC?
Old 02-02-2009, 03:02 PM
SantaCruz163's Avatar
Default Removing TCS but keeping ABS and CC?
I like ABS and cruise control but dislike TCS mainly because of the module and extra cables under the hood. So, is it possible to remove TCS but keep the other 2 fully functional? I would imagine it is possible since TCS was only an option and a car was able to have just ABS and cruise. But what is required (if it is possible) to make it work?
Old 02-02-2009, 07:21 PM
nemss1's Avatar
have to swap out to a 3-channel system and buy a cruise cable that runs to the TB
Old 02-02-2009, 09:31 PM
So a quick run down:
1. Pull the TCS module and cables
2. Buy new non-TCS throttle & CC cables
3. Buy a non-TCS ABS computer
4. Order a 3 channel 9"
That about do it?
Old 02-02-2009, 10:24 PM
SJM Manufacturing Inc's Avatar
That's is quite a bit of money you're going to spend just to retain ABS?? I'd suggest considering removing ABS as well. If you're not aware of our ABS delete kits, you'd be able to remove all the clutter from the engine bay including all brackets (ABS and TCS).
Purchase the rear without ABS, it will be less expensive. Normal braking will not be any different. You'll also have the ability to tune your brake bias since our kits have an adjustable proportioning valve.
The only cables you'll need so you can remove TCS are from your #2 parts list. They are relatively inexpensive.
Old 02-02-2009, 10:39 PM
nemss1's Avatar
That about do it?
yup, thats it
Old 02-03-2009, 07:24 AM
SIC LSX's Avatar
Free!
Do what i did and others did. I un pluged my TCS/ASR and relocated it behind my comuter hides al lcables under cowl! I still have ABS and cruise control and TCS stays off if you want to keep it you will need to add wires to the plug and plug it back up
https://ls1tech.com/forums/appearanc...tion-pics.html
Old 02-03-2009, 01:01 PM
If you unplugged it, why didn't you just remove it instead of stuffing it behind the PCM?
Old 02-03-2009, 01:25 PM
SIC LSX's Avatar
so you dont have to worry about buying and finding all the other cables! Thisi s free and you dont have to find anything. Only takes about 10-15 mins
Quick Reply: Removing TCS but keeping ABS and CC?
