any proven 60'ft times step inside lca question
is there anyone on here that has actual proven 60's with the change of ONLY lcas...from say a BUSHING type lca to a TEFLON(spherical) rod ends such as the pic on the left.....
im wondering is it worth the money to go from a double adjustable bushing type lca to this set up
WILL it be worth the lca and better my 60'foot
maybe UMI can answer this question for me do you have proven 60ft times with the teflon over the bushing type....
Hello
It sounds like the rear is unloading to fast might be a spring or shock situation but another thing what I would recommend is try the second hole on the relocation bracket and doing that will allow the car not to bite so hard. If you have any other question feel free to ask and I will be glad to help, And once again thanks for choosing UMI Performance
Thanks
Brad
Idea!
Hello,
The bushing type depends on how much your car sees the track if you go will rod ends you will get a little road noise. One thing I would recommend is Lower Control Arm Relocation Brackets ( Best bang for the buck). What that does is allow you to move the lowers to three different positions. And allows you to have a better fine tune on the rear. We have experienced that using the lowest holes gives you the best traction performance. below is a link to show you what I am explaining. If you have any other questions feel free to ask I will be more than glad to help.
Thanks Again
Brad
Thanks Again
Brad
If you are trying to make a decision between a poly/poly lower control arm and a rod ended control arm based on 60' difference there is no difference in 60' until you have probably 1000 rwhp or more between the 2 control arms.
So if you already have tubular lower control arms going to the rod end version is not going to better your 60'.
Hope this helps answer your question...
Let me know and we will be glad to assist you. Thanks!
Ryan
Hello
Thanks
Brad
Thanks
Brad
I'll take all the help i can get. i have had the LCA's on the lower hole, since then i have changed springs and shocks, i was on old *** blown cheapo shocks and eibach prokit springs, now im on eibach drag launch springs with about 20 psi in the bag, summit 3 way drag shocks set to Firm (50/50) in the rear, and QA1-R series set all the way soft in the front, I'm only bringing it up to about 1800 for the launch and the weight seems to transfer to the rear nice but it still spins a bit off the line, launches straight now but still spins a but and i cant seem to cut better than a 1.8 60' and definatly cant leave on the bottle. My UMI adjustable TA is waiting in my living room waiting for me to get home from work tomorrow, but unfortunatly i dont think i'll have time to install it before my race tomorrow night. I'm wondering if the 255/60/15 ET Street Radials are not enough tire for the 4.10's. I think that they should be, i know there's faster people than me runnin em. Any ideas on what i should try to hook better and get this darn 60' down?
Perhaps this is the answer the answer your looking for.
yes thats the answer im looking for and the relocation brackets sounds like exactly what i need now thanks
