advantages of rod end over poly ended PHB
Old 03-04-2009, 12:59 PM
Texass683's Avatar
Default advantages of rod end over poly ended PHB
Just wondering what are the advantages of having rod ends instead of poly ends on a PHB. Is it so noticeable to spend the extra money. I have an opportunity to get a poly ended on car adj. phb for $80 so I am trying to determine if it were better to spend the extra $60 for rod ends?
Thanks in advance
Old 03-04-2009, 01:13 PM
LS1TECH Sponsor
Sam Strano's Avatar
Less deflection better axle lateral axle location when under load.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 03-04-2009, 02:12 PM
coolformula's Avatar
Always do it right the first time... and if sam thought it was just and good and cheaper he would tell us
Quick Reply: advantages of rod end over poly ended PHB
