Wheel Hopping
Wheel Hopping
I have a 96 T/A with a built 383 and a lot of suspension work I have the LCA and adjustable torque arm the car is lowered. I get a very nasty wheel hop out of the hole.. Do you think the relocation brackets for the LCA's will help with this problem?? I do have the QA1's on the rear not on the front..Someone told me I should put V6 springs on the front as well....HELP
Lower Control Arm Relocation Brackets
Hello
Lower Control Arm Relocation Brackets were designed to eliminate wheel hop and increase your traction and performance! We have found using the lowest setting on the brackets you get the best traction performance. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Thanks
Brad
It worked for me, I welded mine on, took a test drive, wheel hop was 100% gone.
LS1TECH Sponsor
Because you can have too much of a "good thing". Might bog the car. And running the LCA's tail down from level makes for roll oversteer on the stability side....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I am going to take the car to the track this weekend and I will let you know how it does thanks for all your help.. What do you think about putting the V6 springs on the front? Or is there another option?
I was on my way to the shop to install the relocation brakets and now I have this real bad vibration comming from the rear of the car it starts at about 30 mph and last until I slow down...Any ideas on what this might be????? Thanks
LS1Tech Premium Sponsor
Best thing to do would be try both and see how you like it. Everyones car is different so the hole that works for Joe might not work for Dale. That is if you already have them. All in all if you are having launch or wheel hop issues the relocation brackets will defiantly help a drag car. But like Sam said on a handling based car you might get a negative effect with the tail end of the control arms down too far.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
