had anyone adjusted the rack and pinion preload?
I have heard ALOT of neg comments about how you can screw up the rack so I have never tried.
I am not sure that it would do what you want. It is hard to find a lot of good trustable docs on this.
I am sure that I have read in a gm dealer manual that you should never adjust it at some point in my life.
Here is the best pic I have found to date:
http://www.brakeandfrontend.com/Arti...ting_ball.aspx
it still has no info on how exactly to adjust, what is too much, what is too little.
LS1Tech Premium Sponsor
It really only helps in de powering the rack. A lot of people adjust the tension out of it when they properly get rid of the power steering. I couldnt see how messing with it on a power steering system would help.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Do what? Adjust the tension or de power the rack?
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Taking caster out should reduce some steering effort but at the cost of having less tendency to return to neutral and less high speed stability. Your choice.
I have tried 2 degrees once but IMO it felt like crap. My car is back to 4 again but I am maxed out in the slots and I really want 6.
Caster is adjusted while doing an alignment. If you change the caster the camber and the toe will change. I'm not saying I recommend this but I was running at +4.0 caster and the steering felt very vague and didn't return to center very well. But the effort to turn it was easy.
Just take it to an alignment shop, they can set you up in a matter of mins, but I'm still not sure why you want to reduce steering effort.
