Stock Sway Bars
LS1TECH Sponsor
That's not correct, not unless you got a bastard car... Only way you should have a 21 rear is if you have the Ultra Suspension which also uses a 35mm front. If you have Bilstein's that possible. Not possible if you have deCarbons. Seems you have Bilsteins. The only car that officially had 32/21 stock were 1993 1LE's. For V-8 cars you could have 30/19 (non SS), 32/19 (base SS), or 35/21 (Ultra or SLP's version of 1LE only build in '01-02).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Just spoke to this man. He is not the original owner of the car. He does not know if the car has Ultra Suspension or not. All he can really do is measure the bars and see what he has and not rely on information that may not be correct or accurate for his car. Maybe the original owner added a 21mm himself.
__________________
LS1TECH Sponsor
See.. SLP's "info" was wrong. And this is why you should never assume. You bought, and paid for the wrong bar bushings.... Not from me, because I'd have asked you what bars you had before selling you some.
__________________
