LCA Relocation bracket success.
I know relocation brackets work. On the stock 10 bolt, my car had awesome 60fts but they would not bolt onto my Moser 9"... I was hoping it would "be okay." WRONG.
First track day...Horrible wheel hop, no better than a 1.71 60ft. So, this brings us to tonight. I installed some LCA relocation brackets.
Same weather, same car setup, everything the same except for the relocation brackets.
1.71 60ft to a 1.45 60ft...NOT TOO BAD!
that is a heck of a gain. i wish that i could tell a difference. i went from all stock suspension to a tunnel mounted torque arm, LCA's, relocation brackets, kyb agx shocks, and strano springs. i still hook way worse than my stock setup but i have a feeling that is because i also put in a stall at the same time. i wasn't sure if it is that or if the strano springs are not hooking for me or if something else isn't right... nice times to say the least.
Thanks again
Hello
Its great to hear that everything turned out well for you at the track and you are satisfied with the relocations brackets. And thanks again for your business.....You did get them welded right?
Thanks
Brad
Thanks
Brad
Wow. Thats a pretty good gain. What hole did you run your lca's in? I just put some in mine and havent had a chance to drive it yet. I ran on full slicks last time out for the first time and cut some 1.62's. Couple times I broke them loose but I think I had a bad tire guage, I had to borrow a friends cause evidently mine was waaaay off.. I am curious to see if mine will improve any. The last few runs I had it felt pretty good coming out of the hole, not sure if I will see a gain
I drove mine today with them in and I must say I am pretty impressed on the street. Went for a spirited drive and punched it in 2nd and it didnt break loose till the instant I pushed the clutch at about 6k. Used to a punch in 2nd would just roast them. I was on street tires too which really put a smile on my face
Fun isn't it!
Thanks
Brad
I have relocation brackets and new LCAs on mine. I still seem to break loose, although the wheel hop is gone. Is there something I'm missing here? It's set up on the bottom hole.
After Putting my brackets in I noticed that the rear end felt alot more solid. Now if I do spin there is no wheel hop and its like the rear end is planted better than before. I can't wait to try them out on the track with my new gears and ET Street DR's.
Thanks
Brad
