!@#$ STB in the way of removing the shock! Help?
I got done with the passenger side of the Konis install, went to the driver's and realized "oh crap, I got an Edelbrock STB mounted using the torx bolts I need to unscrew to take the shock out." The previous owner had it put in, and I can't even understand how they did it really... But basically I can't make the master cylinder slide out to reach the torx bolt underneath it because its path is being blocked by the STB mount! And, I can't remove the STB mount because I can't get to that stupid torx bolt. It's a catch 22!!!
I can tilt the master cylinder out of the way just a tad but not enough to put in a torx socket with a ratchet on there...
Ideas anyone?
Thanks!
Ideas anyone?
Thanks!
I think you have to remove the STB from it's mount by removing the horizontal bolt first. From the pic it looks like you need a female torx socket.
Once it's out of the way then you can move the master.
Yes, you'll have to loosen up the brake cylinder. When reinstalling it, put that torx bolt in another spot or just go to Lowe's and buy a hex head bolt.
Edit: Oops, I didn't pay attention that you had the Edlebrock bar...definitely a PITA...
When in doubt, use a hammer.
All right guys, here's how we did it.
We took the T-50 torx socket (http://www.sears.com/shc/s/p_10153_12605_00942667000P) and punched out the actual bit from the socket. We then put that bit into a 5/16" socket in a 3/8" ratchet, and just barely jammed it underneath the master cylinder reservoir into the torx bolt. Using a couple small pipes to extend the leverage on that ratchet we were able to break the torx bolt free. Then, we took a gear wrench, put the T-50 bit through it and removed the bolt. Then, reversed the steps to put it together. All's well that ends well I guess. Even though we felt like
