Strange coilovers
I didn't put them on the car and the ppl that did were lazy and did a shitty job. One side is an inch higher then the back and the other is a half inch high. It didn’t look like there were any bearings under there just 2 "plates" with notches in them.
First, do you have 2 spanner wrenches for the spring seats?
You'll need them to loosen/adjust/tighten the spring seats.
Second, get a can of spray lube and spray it around the base of the spring so the spring seat will turn easier.
IMO,however far you want to raise/lower you car, adjust the lower spring seat up/down half that distance. That will get you really close to where you want it!
