Looking for master bushing kit, in rubber, not poly
Old 04-27-2009, 10:16 AM
slow's Avatar
Default Looking for master bushing kit, in rubber, not poly
Does anybody make this? I want to restore my suspension back to stock comfort.
I am mainly interested in the rears at this time, but I am sure once I do the rears I will want to do the fronts.
For the rears I need the LCA's, Panhard, Swaybar end links, and swaybar bushings, so I assume it would be more cost effective to buy everything at once.
Thanks,
Ryan
Old 04-27-2009, 11:38 AM
Major_Lee_Slow's Avatar
Contact Sam he can set you up with new Moog replacement bushings.
Old 04-27-2009, 12:18 PM
jmilz28's Avatar
Replace your shocks at the same time if real comfort is your goal.
Old 04-27-2009, 01:05 PM
slow's Avatar
I replaced them with bilsteins maybe 8K miles ago, and didn't notice a large change in the rear, if bushing don't help, I'll replace the shocks again with the koni's, but i figured even normal bilsteins on stock ws6 springs should be better than 100K worn out decarbons. Maybe I need new springs as well.
I'll send sam a message, and see what he says.
Thanks,
Ryan
Old 05-05-2009, 12:02 PM
BADFNZ's Avatar
Did you find anything?
Old 05-05-2009, 12:49 PM
slow's Avatar
no, I was not able to find any, I did I find this,
https://ls1tech.com/forums/suspensio...back-dead.html
and I am starting with the rear lca's, and panhard bar, then I will move to the front control arms bushings next
The mog parts seem better than oem for the rear control arms, they're similar to the 1le parts full rubber, not just waffled like the oems
Ryan
Old 05-05-2009, 01:05 PM
Seriously, give Sam a call, he'll have everything you need.
