how do you bleed your ABS block?
Old 09-15-2009, 07:48 AM
ryans01z28's Avatar
Default how do you bleed your ABS block?
how do u bleed the ABS block under the hood. I pulled the motor & unhooked the front brake lines @ the ABS block & now my front brakes are hard as a rock.
Old 09-15-2009, 11:28 AM
Black02SLPSS's Avatar
I think you may need a pressure bleeder. But i have also heard that you hafta get a tech 2 programmer to get everything inside opened up to get all the air out.
Old 09-15-2009, 05:30 PM
SJM Manufacturing Inc's Avatar
A pressure bleeder is not necessary. If you do consider one, use a diaphragm style bleeder, I don’t suggest the type that is a modified garden bug sprayer.
You easiest method requiring no tools would be the "two man method" or using solo bleeders allowing you to bleed the brakes with one person. If you want the solo bleeders, we offer them on our site in the braking section.
A tech tool isn't necessary if you don’t have access to one. You can cycle the ABS modulator manually, and then re-bleed the brakes to remove the dislodged air bubble.
On a side note, rock hard brakes doesn't sound like you've got air in the lines...it sounds like you either connected something incorrectly or you have an inference in a feeding line.
Old 09-15-2009, 08:03 PM
Major_Lee_Slow's Avatar
I have concerns about the speed bleeders (aka solo bleeders). Some road race folks have reported on track failures of these bleeders, therefore I really can't recommend them.
Personally I've had good luck with pressure bleeding, except for the ABS module. When I replaced my ABS module the only way I was able to finally get all the air out of it was by using a Tech II.
Old 09-15-2009, 08:17 PM
ryans01z28's Avatar
wrong, there was air in it. I slammed my foot on the pedal 2wice & the valve came free then I bleed it like normal & works like it should. thanks for the info ppl
Old 09-15-2009, 10:07 PM
eseibel67's Avatar
How can the ABS modulator be cycled manually?
I want to flush my system with clean fluid, and this is what's holding me up.
Old 09-15-2009, 10:11 PM
EchoMirage's Avatar
jack the rear. open the right rear bleeder. start the car, put it in 1st/drive, let it get to idle speed. the ABS block will open when wheel speed is between 6-10 mph. the motive bleeder helps ALOT when doing this. otherwise, itll take hours to totally bleed it. shut the bleeder, turn the motor off. repeat the steps over and over, at each corner.
Old 09-15-2009, 10:32 PM
01ssreda4's Avatar
I did mine about a month ago. I just started at the back and had a buddy pump the brakes till the fluid came clean. It took about 3 reservoirs full to get the line clean. Then rotated around the car one at a time till they were all done.
Old 09-16-2009, 09:20 AM
EchoMirage's Avatar
all that did was flush the lines. it didnt do anything to the ABS block.
Old 09-16-2009, 09:32 PM
svg210's Avatar
the stealership charges you 80 bucks to do it. so..... IMO worth it!
Old 09-18-2009, 11:08 AM
chevroletfreak's Avatar
This sounds interesting. I have been trying to figure out what wires to tap in to in order to bleed the module without the T2.
What solenoid opens when you get to the speed suggested?
Old 09-18-2009, 02:57 PM
svg210's Avatar
the TCS solenoid I guess.
Quick Reply: how do you bleed your ABS block?
