Which ABS delete kit?
Old 10-30-2009, 10:38 PM
913MOTOR's Avatar
Default Which ABS delete kit?
I have a 96 trans am and looking at the two SJM kits. One is regular and one is hurst style. Anyone care to explain?
Old 10-31-2009, 07:33 PM
SJMMFGINC's Avatar
One is using our SJM style solenoid; one uses a Hurst style solenoid. For all intensive purposes, difference is in the solenoid itself. It's an esthetic difference, not performance. Cost difference is due primarily from the solenoids.
Both are offered for choices to the end user, that's all.
Old 11-03-2009, 09:55 PM
913MOTOR's Avatar
one last question, how can i tell if I have 3 or 4 channel abs?
Old 11-04-2009, 01:31 PM
tko0383's Avatar
https://ls1tech.com/forums/gears-axl...r-end-faq.html
15. What's the difference between a 3 channel and 4 channel rear?
A three channel rear end has ABS. A 4 channel rear end has ABS and traction control. A 'channel' is just a way of describing the means for a speed sensor to gauge the wheel speed. On a 3 channel rear end, the two front wheels have sensors, and there is one sensor on top of the rear end housing that reads for the whole rear. On a 4 channel rear end, there is a speed sensor at every wheel. 4 channel rear ends have reluctor wheels on each axle, 3 channel rears have one big reluctor ring on the differential. Because a 4 channel has a sensor at each rear wheel it can see the difference in speed between one wheel and the other, and ta-da, you have traction control.
Old 11-04-2009, 04:45 PM
913MOTOR's Avatar
duhh I looked in braking not rear end, got no TCS therefore 3 channel. Thanks
Old 11-05-2009, 06:37 AM
Higgs Boson's Avatar
Originally Posted by SJMMFGINC
....For all intensive purposes,....
surely you jest.
Old 11-05-2009, 02:58 PM
SPEED#1's Avatar
sjm hands down
Old 11-05-2009, 05:59 PM
litch2004's Avatar
SJM FTW:
Like stated above their really isnt any difference besides the name and the lower connection point on the hurst i believe is different. Pictured above is mine with the SJM solenoid.
Quick Reply: Which ABS delete kit?
