speed bumps, how do you hit them?
Old 11-16-2009, 10:23 AM
tuffluck's Avatar
Default speed bumps, how do you hit them?
my car is lowered so my suspension is pretty stiff. my parking garage for work is ridiculous with about 581 speed bumps, and they are speed bumps from hell. usually i try to go over just one side of my car and the space in between speed bumps in go through with my driver's side tire. should you hit speed bumps square though, i mean is it better for your suspension? or just hitting them with one tire is okay?
Old 11-16-2009, 10:39 AM
ncfastls1's Avatar
I can't see how that would harm your suspension at all. I usually have to go inbetween the bumps or try to go as sideways as possible and my car isn't even lowered. The cats on my y-pipe are what scrapes, I fear I'll never be able to lower it.
Old 11-16-2009, 02:10 PM
SOMbitch's Avatar
What you are doing is fine, When I have to drive all tires over one I hit it at an angle.
Old 11-16-2009, 02:21 PM
Mean Green z28's Avatar
as long as you're not hitting them at 65mph, you'll be fine ... lol
Old 11-16-2009, 06:40 PM
billyb's Avatar
i had the torque arm bracket for long tubes and hit everything, but now i have the one without the dp in it andi don;t hit any more 02 firehawk blisten suspension , and it sit low from slp.
Old 11-16-2009, 09:40 PM
Ponch95's Avatar
You can always down shift and slam your foot on the gas and try to fly over them
j/k kinda
Old 11-16-2009, 09:58 PM
zbugger's Avatar
I go over speed bumps pretty damn slow. If I can, I hit them at an angle and just roll over them, but I usually wind up hitting them straight on. I accidentally let my foot off the clutch today and bounced a little, slamming the car on the bump. Scared the hell out of me and I'm still looking for an oil spot or something under the car. My 2000 Z28 is dropped with Eibach's, by the way.
Old 11-17-2009, 06:08 AM
leethomas001's Avatar
Hitting the hump directly will give great problem to the car...sometime the shoe brake breaks and it i very dangerous..so you should go zic zac way..that will be the best way
Old 11-17-2009, 11:06 AM
meine96ws6's Avatar
def at an angle..with my car lowered and with longtubes.. i kinda have to creep over them..
Old 11-17-2009, 12:45 PM
Jolly's Avatar
Now that mines lowered I drag everything that isn't flat. Y pipe is the problem on mine.
Old 11-17-2009, 01:14 PM
S2K
S2K's Avatar
Location: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
I go at them straight on and slow.
Old 11-17-2009, 03:35 PM
99Bluz28's Avatar
Very slow on the SB's.
If you know where it scrapes the most then clamp a U-bolt in that location, that way the U-bolt takes the wear not the exhaust pipe.
Old 11-17-2009, 04:15 PM
tuffluck's Avatar
i figure stock exhaust isn't something i am too concerned about scraping, as long as it isn't a hit so hard that it could somehow send a jolt up through the pipes to the headers and crack the block or something...
Old 11-17-2009, 08:39 PM
tillery's Avatar
I dont go flying into them. But I dont baby the car.
Quick Reply: speed bumps, how do you hit them?
