Best Lowing Springs to Buy
Old 12-07-2009, 03:42 PM
Auto's Avatar
Default Best Lowing Springs to Buy
I wanted to buy a set of lowing springs for 01 SS. I am unsure of what to buy does anyone have any suggestions. The car is not my daily driver. I auto cross the car a couple times a year as well as end up at the drag strip a couple times a year. Any suggestions please.
Old 12-07-2009, 03:49 PM
tko0383's Avatar
Sam Strano is your man for the springs. Do a search for Strano Springs and you will find everything you need to know.
Old 12-07-2009, 04:28 PM
02 Silver SS's Avatar
+1 for Strano - 275 shipped to your house - 550lbs front and 150lbs back.
Old 12-07-2009, 05:29 PM
z28bryan's Avatar
I'd definitely go with Strano. Paired up with the right shocks, my car was more comfortable than many cars I've driven in stock form. You won't be disappointed.
Old 12-07-2009, 05:48 PM
egott_91's Avatar
Like everyone else has said, Stranos. That's what I'm going with in the Summer.
Old 12-07-2009, 05:59 PM
LS1TECH Sponsor
Sam Strano's Avatar
I feel my springs are the springs you'd want. Lighter than most every other spring in terms of actual weight. Proven to handle via wins and lap times. Speced by me, to be what I wanted, based off of lots of trial and error testing with coil-overs.
There are cheaper springs. There are springs that claim to be pretty much the same. There are copies. There is only one set that has the results to back up the claims. And frankly you can see that those that have 'em are pleased with them.
Aside from balance, part of autox is getting power down (you know, you do it), so my springs are pretty good drag springs too--as far as lowering springs go.
They are $275 shipped. I'm awaiting a shipment now, due into port on the 9th. Hoping like hell Customs doens't screw around and I get them shortly thereafter. 100 sets there or thereabout are coming. Some 35 are already sold.
If you are interested, I recommend placing an order sooner than later to insure you get a set. Note: There is no charge to your Credit Card until the springs are ready to ship--only then are you billed.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 12-07-2009, 06:54 PM
xXxSilveradoxXx's Avatar
Stranos FTW!
Old 12-07-2009, 06:59 PM
2 ROWDY's Avatar
Stranos are good.
Old 12-07-2009, 09:22 PM
LastBlack02SS's Avatar
+1 For Sam.
Old 12-07-2009, 10:50 PM
homerunhtr21's Avatar
+100 for Strano...Pics for a visual
Old 12-07-2009, 11:27 PM
StealthFormula's Avatar
I vote for Strano as well. I installed mine a couple years ago and have been very pleased with them. I currently run them with the stock shocks still and even with that not at being an optimal drag setup I still cut consistent mid 1.5x 60's in a car with just 360rwhp at almost full weight. I drive the car hard on and off the track and they handle really well, look great and in my opinion launch pretty damn good for being a lowering spring.
Old 12-08-2009, 07:09 AM
Auto's Avatar
You guys have convinced me that the only good choice is Strano. Sam I will be in touch with you over the next day or two to order a set. Homerunhtr21 thanks for the pic’s that is defiantly the stance I am looking for on my car.
Auto's Avatar
Does anyone know what he factory spring rates are.
Old 12-08-2009, 07:23 AM
teke184's Avatar
list of most fbody springs
Old 12-08-2009, 08:29 AM
Auto's Avatar
Thanks for the spring rates. Now the higher the rate the stiffer the spring correct or incorrect.
Old 12-08-2009, 09:10 AM
teke184's Avatar
basically yeah.
Old 12-08-2009, 09:12 AM
z28bryan's Avatar
Plus he'll give you lots of setup advice and help you get what you want. Not too bad coming from an SCCA autox multinational winner
Quick Reply: Best Lowing Springs to Buy
