Lighter weight oem rear brake calipers
An to think that is our retrofit front brake kit to retain ABS, if you did the full Strange brake kit using the aluminum hubs there is a few more pounds to be saved.
Strange 12 bolt, lightweight spool, 4.10s, 33 spline axles.
Full info, weights, pics, assembly, powder coating etc:
https://ls1tech.com/forums/gears-axl...t-install.html
I think the aluminum hubs would save another 5lbs per side.
Rear Brake Kit
F-Body Strange Rear Brake Kit B1718WC
Rear brake kit for Strange 3.150" Small GM housing ends
Requires appropriate Strange axles using 1/2" or 5/8" screw-in wheel studs
Brake offset = 2.832"
The full kit replaces the wheel bearing and wheel flange. Those will not work with stock wheels. You must keep the stock wheel bearing to run a stock wheel.
DO you drive your car on the street at all? I am curious at how they perform as i was thinking about doing the front setup as well. I have the rear setup on the way. My other option was running a c5 rotor setup on front. Good bit of roll racing and some drag strip time. id say 60/70 percent street.
