lca relocation brackets. how to install. welded ones.
Old 04-28-2010, 03:41 PM
nobird8991's Avatar
Default lca relocation brackets. how to install. welded ones.
i have these umi weld on relocation brackets for my new moser 9'' housing but i wanted to put them on and get them welded before powder coat but then if i understand the car rear end has to be in the car suspension loaded but i have a problem. i have no transmission or anything yet to mount the tq arm to. is there any other way to know where to weld these brackets on?
thanks,
jeremy.
Old 04-28-2010, 04:10 PM
hlaalu's Avatar
They should still have holes where you get bolt them on where they should go, then just weld them in.
Old 04-28-2010, 04:40 PM
nobird8991's Avatar
i see that yes but there is only 1 bolt hole to bolt them in and they can pivot. they need to have a precise angle for them to work. see what i'm saying?
Old 04-28-2010, 07:34 PM
hlaalu's Avatar
Yes, the back of the brackets should match up with the existing brackets. I'll try and find a picture for you
Old 04-28-2010, 11:43 PM
nobird8991's Avatar
ok cool that'd be sweet.
Old 04-29-2010, 07:52 AM
UMI Sales's Avatar
Hello
I understand that you have a few questions about installing the weld on relocation brackets. When you have a chance pm me your email address and I will be more than glad to email you the installation instructions. If you have any other questions feel free to ask.
Thanks
Brad
Old 04-29-2010, 11:46 PM
nobird8991's Avatar
don't see what you mean. i try to put them on and they still just turn to all different angles.
Old 04-30-2010, 08:00 AM
UMI Performance's Avatar
Usually we place the rear end under the car first and line the brackets up where they need to be, then weld them on and pull the rear back out.
Quick Reply: lca relocation brackets. how to install. welded ones.
