UMI A-arms, overtorque lower balljoint
Old 05-22-2010, 03:31 PM
bigblueturtle's Avatar
Default UMI A-arms, overtorque lower balljoint
castle nut slot did not align with the cotter pin hole at 79 ft-lbs, it was either stop at 65 ft-lbs or go to 100 ft-lbs
I went to 100... Is this too much?
Old 05-22-2010, 04:49 PM
sjsingle1's Avatar
its alright to back off to line up the pin
Old 05-23-2010, 02:18 PM
Moog says to never back the nut off, rather, to keep going to the next slot... but 100 compared to 79 seems like a lot, don't want it to break while driving... should I pop the joint and reseat to 65
Old 05-23-2010, 03:53 PM
mitchntx's Avatar
A 3500lb car hits a curb and all it does it knock it out of alignment. Happens all the time. I venture a guess the loading on that ball joint would be a tad more than 100ft/lbs.
My guess is that after 50K miles, it will be a real bitch to get that nut off will be the only fall-out front your over-tightening it.
Old 05-23-2010, 04:24 PM
Kleeborp the Moderator™
MeentSS02's Avatar
That's a big fat negative.
Old 05-23-2010, 09:14 PM
99345hp's Avatar
yeah, i always go to the next slot on a castle nut to install the cotter pin. I never go backwards.
Old 05-23-2010, 09:21 PM
sjsingle1's Avatar
i say that cuz i read it sum where..............dont know where...............but i did
Old 05-24-2010, 07:34 AM
UMI Sales's Avatar
Hello
Like mentioned above torque it to the designate spec. And then just use a box wrench and turn it until the carter key lines up. Torquing the castle nut to 100 lbs is not necessary.
Thanks
Brad
Quick Reply: UMI A-arms, overtorque lower balljoint
