rear spring spacers
Old 06-04-2010, 05:12 AM
vatechguy3's Avatar
Default rear spring spacers
so i'm having a little bit of rubbing with my 295/35-18s in the rear whenever i go over bumps fast or during hard cornering.
i would like to put a small spacer, about 1/8" - 1/4", between the upper spring isolator and the upper spring mount.
something like this from mc-master carr
http://www.mcmaster.com/#9515k611/=7dt9xe
part number - 9515K611
i know its 3/8" thick, but thats all i could find.
what do you guys think?
any other suggestions?
thanks
tony
Old 06-05-2010, 08:50 PM
HavATampa's Avatar
Subscribe >>>> https://ls1tech.com/forums/showthrea...ferrerid=13535
Old 06-05-2010, 08:58 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I've used Mr. Gasket (part no. 1287) spring spacers with success in the back...how much it raises the car depends on where you put it on the coil. It gave me about 1/2" back there...
Old 06-10-2010, 05:45 AM
vatechguy3's Avatar
do those change the spring rate?
tony
Old 06-11-2010, 11:38 AM
MeentSS02's Avatar
I'm guessing it does...I put mine on an active part of the coil, but I didn't really notice anything when I actually drove it after the install.
Old 06-13-2010, 04:29 PM
vatechguy3's Avatar
could you have gotten less than 1/2" using a different location?
tony
Old 06-23-2010, 03:14 PM
vatechguy3's Avatar
so i'm thinking about buying something like from this site:
http://www.energysuspensionparts.com...-Isolators.asp
so, my springs are installed. can someone tell me the dimensions of strano rear springs so i can figure out which one i need for an ls1 car??
thanks
tony
Old 06-23-2010, 03:55 PM
z28bryan's Avatar
How is a spring spacer going to change springrate???
Old 06-23-2010, 04:22 PM
FirstYrLS1Z's Avatar
the use of a spring spacer changes felt/perceived 'spring rate' because of fewer active coils.
Old 06-23-2010, 07:52 PM
z28bryan's Avatar
Sorry to be a pain, but how does a spacer cause there to be fewer active coils? I thought a spacer just seats the spring higher.
Old 06-28-2010, 12:22 PM
vatechguy3's Avatar
there are two kinds of spacers.
one goes either above or below the spring to provide additional "height" to the spring. this does not change anything about the spring or how it works.
the second goes inbetween the coils of the spring and therefore does not allow the spring to compress as much under load. this changes the spring rate of the spring by not allowing it to compress over its entire length.
tony
Old 07-07-2010, 05:47 AM
vatechguy3's Avatar
anyone???
tony
Quick Reply: rear spring spacers
