clunk from rear after LCA install
Old 07-14-2010, 06:09 PM
infinitebird's Avatar
Default clunk from rear after LCA install
Ok I recently got my LCAs from UMI installed. they are the poly/roto joint ones.
But now, any time I go over even small bumps, and sometimes even on smooth road, I hear this noticeable clunking sound coming from the rear. It isn't a vibration I can feel really, just a semi-lound clunking noise.
Is this normal just because it is a harder bushing or does this mean something is too tight or too loose or something like that is setup wrong?
Old 07-15-2010, 07:20 AM
UMI Sales's Avatar
Hello
Thanks for choosing UMI Performance for your suspension needs. It sounds like you have a issues with the hardware not being tight (it can work loose). I would suggest making sure that everything is torqued down to 90ft lbs. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Old 07-15-2010, 09:47 AM
LWCS561's Avatar
ive heard about this too. it happens on mine, although it sounds like more of a rattling. I was told that because of it being a roto joint, that it tends to rattle. not that its loose, but thats just how the joint is. i even had the shop go back over and tighten everything
Old 07-15-2010, 09:58 AM
1nastyss's Avatar
Make sure everything is tight and the poly bushing has grease in it
Old 07-15-2010, 10:07 AM
Camaro Junky's Avatar
When my Spohn LCAs where loose, I would hear the same thing. There could be a slight rattle here and there after I tightened the LCAs, but I would only hear it going over huge bumps. If it bothers you, just get this from UMI.
Old 07-15-2010, 01:18 PM
ok thanks I will check the torque and see if it's loose. If not then I guess maybe it's normal.
Quick Reply: clunk from rear after LCA install
